Hi all,
I am working on a data logging project using the Adafruit Feather 32u4 Adalogger to log data to the SD card. The SD card then dumps data over the serial port.
I want the data to dump/print over the serial port only when it is plugged into the computer and the serial monitor is open. This is easy, BUT, once my Arduino know the serial port is open it thinks it is open even when I remove the Arduino from the computer and run it on battery power.
Here is a super simplified example of my code:
pinMode(13, OUTPUT);
CheckPluggedIn();
void CheckPluggedIn()
if (Serial)
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
When I open the serial monitor the LED turns on, but when I close the monitor or unplug the Arduino the LED stays on...
Any help is much appreciated.
