How to temporarily change expected signature for atmega32?
Hi, I'm using Atmega32A with Arduino as ISP. I use mightycore boards library. I burned the bootloader on it as it would be atmega32, everything worked, but when I tried to upload a sketch on it, an error as below occurred. Furthermore, I think the problem is that atmega32A isn't the same thing as atmega32, and I have to change board in Arduino IDE to atmega32, but how? I can't find it. Maybe I can temporarily change the expected signature for atmega32 for the atmega32A one? Or possibly I can just force it, but I don't know how to do -F thing.
Error after trying to upload a sketch on atmega32A [Boards: atmega32]
avrdude: Expected signature for ATmega32 is 1E 95 02
         Double check chip, or use -F to override this check.
Do not use -F. You will need boar definition for ATmega32A, but as I see in the DS the signature is the same for both 0x1E9502. It looks more like problem with communication. Make sure the bootloader is uploaded correctly and also your wiring have to be correct.
