I get data from one Arduino to an other (Stalker to Yun) via radio with the RFM69 lib GitHub - LowPowerLab/RFM69: RFM69 library for RFM69W, RFM69HW, RFM69CW, RFM69HCW (semtech SX1231, SX1231H)
The lib writes the incoming data in a for loop to serial
for (byte i = 0; i < radio.DATALEN; i++) {
Serial.print((char)radio.DATA[i]);
Serial.print(" [RX_RSSI:");Serial.print(radio.RSSI);Serial.print("]");
I tried to fill a char variable in parallel of writing to serial via
char outputSd[radio.DATALEN+1];
outputSd[i] = (char)radio.DATA[i];
Atfer checking the output on the SD I noticed some odd characters at the end, the serial monitor says
#[12][2] 2015/05/21 00:49:24, 25.4, 22.2, 36, 8.625 [RX_RSSI:-64]
outputSd: 2015/05/21 00:49:24, 25.4, 22.2, 36, 8.6259Bé
on the SD via a terminal and # less I get
2015/05/21 00:34:54, 25.5, 22.2, 36, 8.624BéAM
2015/05/21 00:35:04, 25.5, 22.2, 36, 8.625BéAM
2015/05/21 00:35:14, 25.5, 22.2, 35, 8.626BéAM
I think the array is not terminated correctly. But
outputSd[radio.DATALEN+1] = '\0';
or
outputSd[radio.DATALEN+1] = 0;
does not help.
My problem is
- do I have to terminate the char array manually?
- if so on which position should I terminate radio.DATALEN+1 or radio.DATALEN
- do I have to use = '\0' or = '0'; or = 0; or = NULL ??
