https://github.com/janelia-arduino/TMC2209/blob/main/examples/BidirectionalCommunication/SettingsAndStatus/SettingsAndStatus.ino
Pintout:
Mega TMC2099
15RX3 ↔ TX
#include <TMC2209.h>
// This example will not work on Arduino boards without HardwareSerial ports,
// such as the Uno, Nano, and Mini.
// See this reference for more details:
// https://www.arduino.cc/reference/en/language/functions/communication/serial/
HardwareSerial & serial_stream = Serial3;
const long SERIAL_BAUD_RATE = 115200;
const int DELAY = 2000;
// Instantiate TMC2209
TMC2209 stepper_driver;
Serial.begin(SERIAL_BAUD_RATE);
stepper_driver.setup(serial_stream);
// Serial.println("*************************");
// Serial.println("getSettings()");
TMC2209::Settings settings = stepper_driver.getSettings();
// Serial.print("settings.is_communicating = ");
// Serial.println(settings.is_communicating);
// Serial.print("settings.is_setup = ");
// Serial.println(settings.is_setup);
// Serial.print("settings.software_enabled = ");
// Serial.println(settings.software_enabled);
// Serial.print("settings.microsteps_per_step = ");
// Serial.println(settings.microsteps_per_step);
// Serial.print("settings.inverse_motor_direction_enabled = ");
// Serial.println(settings.inverse_motor_direction_enabled);
// Serial.print("settings.stealth_chop_enabled = ");
// Serial.println(settings.stealth_chop_enabled);
// Serial.print("settings.standstill_mode = ");
switch (settings.standstill_mode)
case TMC2209::NORMAL:
Serial.println("normal");
case TMC2209::FREEWHEELING:
Serial.println("freewheeling");
case TMC2209::STRONG_BRAKING:
Serial.println("strong_braking");
case TMC2209::BRAKING:
Serial.println("braking");
// Serial.print("settings.irun_percent = ");
// Serial.println(settings.irun_percent);
// Serial.print("settings.irun_register_value = ");
// Serial.println(settings.irun_register_value);
// Serial.print("settings.ihold_percent = ");
// Serial.println(settings.ihold_percent);
// Serial.print("settings.ihold_register_value = ");
// Serial.println(settings.ihold_register_value);
// Serial.print("settings.iholddelay_percent = ");
// Serial.println(settings.iholddelay_percent);
// Serial.print("settings.iholddelay_register_value = ");
// Serial.println(settings.iholddelay_register_value);
// Serial.print("settings.automatic_current_scaling_enabled = ");
// Serial.println(settings.automatic_current_scaling_enabled);
// Serial.print("settings.automatic_gradient_adaptation_enabled = ");
// Serial.println(settings.automatic_gradient_adaptation_enabled);
// Serial.print("settings.pwm_offset = ");
// Serial.println(settings.pwm_offset);
// Serial.print("settings.pwm_gradient = ");
// Serial.println(settings.pwm_gradient);
// Serial.print("settings.cool_step_enabled = ");
// Serial.println(settings.cool_step_enabled);
// Serial.print("settings.analog_current_scaling_enabled = ");
// Serial.println(settings.analog_current_scaling_enabled);
// Serial.print("settings.internal_sense_resistors_enabled = ");
// Serial.println(settings.internal_sense_resistors_enabled);
// Serial.println();
// Serial.println("hardwareDisabled()");
bool hardware_disabled = stepper_driver.hardwareDisabled();
// Serial.print("hardware_disabled = ");
// Serial.println(hardware_disabled);
// Serial.println("getStatus()");
TMC2209::Status status = stepper_driver.getStatus();
if (status.over_temperature_warning == 1) {
Serial.print("status.over_temperature_warning = ");
Serial.println(status.over_temperature_warning);
if (status.over_temperature_shutdown == 1) {
Serial.print("status.over_temperature_shutdown = ");
Serial.println(status.over_temperature_shutdown);
if (status.short_to_ground_a == 1) {
Serial.print("status.short_to_ground_a = ");
Serial.println(status.short_to_ground_a);
if (status.short_to_ground_b == 1) {
Serial.print("status.short_to_ground_b = ");
Serial.println(status.short_to_ground_b);
if (status.low_side_short_a == 1) {
Serial.print("status.low_side_short_a = ");
Serial.println(status.low_side_short_a);
if (status.low_side_short_b == 1) {
Serial.print("status.low_side_short_b = ");
Serial.println(status.low_side_short_b);
if (status.open_load_a == 1) {
Serial.print("status.open_load_a = ");
Serial.println(status.open_load_a);
if (status.open_load_b == 1) {
Serial.print("status.open_load_b = ");
Serial.println(status.open_load_b);
if (status.over_temperature_120c == 1) {
Serial.print("status.over_temperature_120c = ");
Serial.println(status.over_temperature_120c);
if (status.over_temperature_143c == 1) {
Serial.print("status.over_temperature_143c = ");
Serial.println(status.over_temperature_143c);
if (status.over_temperature_150c == 1) {
Serial.print("status.over_temperature_150c = ");
Serial.println(status.over_temperature_150c);
if (status.over_temperature_157c == 1) {
Serial.print("status.over_temperature_157c = ");
Serial.println(status.over_temperature_157c);
if (status.current_scaling == 1) {
Serial.print("status.current_scaling = ");
Serial.println(status.current_scaling);
if (status.stealth_chop_mode == 1) {
Serial.print("status.stealth_chop_mode = ");
Serial.println(status.stealth_chop_mode);
if (status.standstill == 1) {
Serial.print("status.standstill = ");
Serial.println(status.standstill);
delay(DELAY);
I'm using a Mega. I connected RX3 to the TMC2099's TX.
Is that right?
Do the settings need to be modified? Or should it work with the commented out sections?
I ran the motor at high current (potentiometer cracked all the way up) without a heat sink. It stop/started after a few minutes but the status in the serial monitor had no change. Nothing output differently.
