I want to toggle 1 led. When button is pressed led comes on and when pressed again goes off.
That will be a state change then. Look in the IDE under File-> Examples -> 02 Digital -> StateChangeDetection
is there a way to do it without buttonpushcounter
Did your try? StateChangeDetection
Here you go (connect button to PIN2 and ground):
const int buttonPin = 2; // button is connected to pin
bool buttonState = 0; // variable to hold the button state
bool Mode = 0; // What mode is the light in?
pinMode(buttonPin, INPUT_PULLUP); // Set the switch pin as input
pinMode(LED_BUILTIN, OUTPUT);
if (!digitalRead(buttonPin)) // cheks if button is pressed (cheks if it's LOW, becouse PULLUP inverts signal: LOW = button pressed)
if (!buttonState) // same as: (buttonState == false) ---I made it a bit compact, but it may be confusinf to you
buttonState = true;
Mode = !Mode; // this inverts button mode: If Mode was True - it will make it False and viseversa
else buttonState = false;
// blink LED
digitalWrite(LED_BUILTIN, Mode); // remember: TRUE = HIGH = 1 and FALSE = LOW = 0 (You can use whatever You like)
delay(5);
Shorter version.
Leo..
const byte buttonPin = 2; // button between pin2 and ground
if (!digitalRead(buttonPin)) {
digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
ap16:
You need to know what the last state produced by the button to know what the next state should be. So how ever you dress it up you have to count the presesses up to a maximum of two.
What does that question really mean? Does it mean you can’t understand the example and you think we deliberately want to make things complex?
I am sorry for answering an old post. But I hope it is useful for some googling this issue. You can see how to toggle LED by button in this tutorial. The tutorial includes code WITH and WITHOUT debouncing
IoT_hobbyist:
I don't like, when old posts are getting pushed.
The 3 answers from 2018 were ok and are still ok.
The "solutions" in your linked tutorial ain't no better than the provided solutions. Using "int" for each and any variable is bad coding behavior!
