How to transfer a little program from a UNO to a esp8266 board
Title says it all really.
I have a little display running on an Oled, on a UNO. I would like to transfer it to an ESP8266. The problem is, as I understand it, the ESP8266 has only one Analogue pin and the program specifies more.
Can this be done?
Does it have to be an ESP8266 or could it be something else such as an ESP32 ?
Where does the analogue pin come into play? Is the OLED an I2C device? Is it because you use A4 and A5 on your UNO?
EDIT: I just read that the 8266 doesn't have hardware I2C. There is a software I2C library available. But what I read could be wrong!!
If You have some digital outputs available they could control an analogue multiplexer.
do you have the source code?
First question: why do you want to transfer it?
J-M-L Jackson
markd833
Code now attached.
UKHeliBob
ell, I have several ...
I believe so (novice alert)
Much more compact footprint.
Less expensive.
Much more memory.
I am keen to learn…
// Display - https://pmdway.com/collections/oled-displays/products/0-49-64-x-32-white-graphic-oled-i2c
// Guide - https://pmdway.com/blogs/product-guides-for-arduino/tutorial-using-the-0-49-64-x-32-graphic-i2c-oled-display-with-arduino
#include <Arduino.h>
#include <U8g2lib.h>
#include <Wire.h>
U8G2_SSD1306_128X64_ALT0_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
  u8g2.begin();
// fonts https://github.com/olikraus/u8g2/wiki/fntlistall#4-pixel-height
  u8g2.clearBuffer();          // clear the internal memory
  u8g2.setFont(u8g2_font_ncenB14_te);  // choose a suitable font
    u8g2.drawStr(10, 23, "Hello,");  // write something to the internal memory
  u8g2.drawStr(70, 23, "I'm ...");
  u8g2.sendBuffer();          // transfer internal memory to the display
  delay(4500);
  u8g2.setFont(u8g2_font_ncenR12_te);  // choose a suitable font
  u8g2.drawStr(10, 12, "BRENNAN");  // write something to the internal memory
  u8g2.drawStr(10, 32, "MAC");
  delay(5000);
 // u8g2.setFont(u8g2_font_tenstamps_mf);  // choose a suitable font
  u8g2.drawStr(7, 23, "O'CONNOR");  // write something to the internal memory
  delay(4000);
I may me talking nonsense regarding the pins??
I forgot to say thanks
P.S. Video attached - just a little "proof of concept" using my 1yo grandson :grinning:
https://i.imgur.com/8a6M98L.mp4
Yes, you are !
The I2C interface uses pins A4 and A5 on the Atmege328 but they are not being used as analogue pins
When you move the program to the ESP8266 you will need to use its I2C pins which you define in the sketch
See ESP8266 Pinout Reference: Which GPIO pins should you use? | Random Nerd Tutorials
Fair enough.
I have looked at that link, but still mostly a mystery to me.
As I said earlier... NOVICE.
I am "guessing", D1 & D2 pins.
Can anyone indicate what needs changing in my existing code to make it work with a ESP8266?
Yes, D1 and D2 are the pins you want on the ESP8266
This works for me
#include <Wire.h>
U8G2_SSD1306_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
void setup(void)
  u8g2.begin();
  u8g2.setFont(u8g2_font_ncenB12_tr);
  u8g2.clearBuffer();
  u8g2.drawStr(10, 10, "Hello World");
  u8g2.sendBuffer();
void loop(void)
Mike Rankin has some very easy to use SSD1306 code:
GitHub - mike-rankin/ESP_LUA_Loader
I have a note in code from 2015 stating:
Author of OLED routines:
  https://github.com/mike-rankin/ESP_LUA_Loader
  Oled Display has an i2c address of 0x0C (even if it says 0x78)
  ESP-01 has only two I/O pins: 0=SDA, 2=SCL
I have utilized the lib, but years back.
SSD1306.h
#define OLED_address  0x3c      // OLED I2C bus address
//function prototypes required for Tabbed Includes
static void reset_display(void);
void displayOn(void);
void displayOff(void);
static void clear_display(void);
static void SendChar(unsigned char data);
static void sendCharXY(unsigned char data, int X, int Y);
static void sendcommand(unsigned char com);
static void setXY(unsigned char row, unsigned char col);
static void sendStr(unsigned char *string);
static void sendStrXY( char *string, int X, int Y);
static void init_OLED(void);
static void reset_display(void) // Resets display depending on the actual mode
  displayOff();
  clear_display();
  displayOn();
  sendcommand(0xaf);          //display on
  sendcommand(0xae);		//display off
  unsigned char i, k;
  for (k = 0; k < 8; k++)
    setXY(k, 0);
      for (i = 0; i < 128; i++)
        SendChar(0);            // Clears the display by sendind 0 to all the screen map.
// Actually this sends a byte, not a char to draw in the display.
// Display's chars uses 8 byte font the small ones and 96 bytes
// for the big number font.
  Wire.beginTransmission(OLED_address); // begin transmitting
  Wire.write(0x40);             //data mode
  Wire.write(data);
  Wire.endTransmission();       // stop transmitting
// Prints a display char (not just a byte) in coordinates X Y,
// being multiples of 8. This means we have 16 COLS (0-15)
// and 8 ROWS (0-7).
  setXY(X, Y);
  for (int i = 0; i < 8; i++)
    Wire.write(pgm_read_byte(myFont[data - 0x20] + i));
// Used to send commands to the display.
  Wire.beginTransmission(OLED_address);     //begin transmitting
  Wire.write(0x80);             //command mode
  Wire.write(com);
// Set the cursor position in a 16 COL * 8 ROW map.
  sendcommand(0xb0 + row);                  //set page address
  sendcommand(0x00 + (8 * col & 0x0f));     //set low col address
  sendcommand(0x10 + ((8 * col >> 4) & 0x0f)); //set high col address
// Prints a string regardless the cursor position.
  unsigned char i = 0;
  while (*string)
    for (i = 0; i < 8; i++)
      SendChar(pgm_read_byte(myFont[*string - 0x20] + i));
    *string++;
// Prints a string in coordinates X Y, being multiples of 8.
// This means we have 16 COLS (0-15) and 8 ROWS (0-7).
  setXY(X, Y);
  while (*string)
    *string++;
// Inits 128x64 OLED and draws logo at startup
  sendcommand(0xae);		// display off
  sendcommand(0xa6);            // Set Normal Display (default)
  sendcommand(0xAE);            // DISPLAYOFF
  sendcommand(0xD5);            // SETDISPLAYCLOCKDIV
  sendcommand(0x80);            // the suggested ratio 0x80
  sendcommand(0xA8);            // SSD1306_SETMULTIPLEX
  sendcommand(0x2F);            // 1/48 duty
  sendcommand(0xD3);            // SETDISPLAYOFFSET
  sendcommand(0x0);             // no offset
  sendcommand(0x40 | 0x0);      // SETSTARTLINE
  sendcommand(0x8D);            // CHARGEPUMP
  sendcommand(0x14);
  sendcommand(0x20);            // MEMORYMODE
  sendcommand(0x00);            // 0x0 act like ks0108
  sendcommand(0xA0 | 0x1);      // SEGREMAP  Rotate screen 180 deg
  //sendcommand(0xA0);
  sendcommand(0xC8);            // COMSCANDEC  Rotate screen 180 Deg
  //sendcommand(0xC0);
  sendcommand(0xDA);            // 0xDA
  sendcommand(0x12);            // COMSCANDEC
  sendcommand(0x81);            // SETCONTRAS
  sendcommand(0xCF);            //
  sendcommand(0xd9);            // SETPRECHARGE
  sendcommand(0xF1);
  sendcommand(0xDB);            // SETVCOMDETECT
  sendcommand(0x40);
  sendcommand(0xA4);            // DISPLAYALLON_RESUME
  sendcommand(0xA6);            // NORMALDISPLAY
  clear_display();
  sendcommand(0x2e);            // stop scroll
  //----------------------------REVERSE comments----------------------------//
  //  sendcommand(0xa0);	// seg re-map 0->127(default)
  //  sendcommand(0xa1);	// seg re-map 127->0
  //  sendcommand(0xc8);
  //  delay(1000);
  // sendcommand(0xa7);        // Set Inverse Display
  // sendcommand(0xae);	       // display off
  sendcommand(0x20);           // Set Memory Addressing Mode
  sendcommand(0x00);           // Set Memory Addressing Mode ab Horizontal addressing mode
  //  sendcommand(0x02);       // Set Memory Addressing Mode ab Page addressing mode(RESET)
  setXY(0, 0);
  for(int i=0;i<128*8;i++)     // show 128* 64 Logo
    SendChar(pgm_read_byte(logo+i));
  sendcommand(0xaf);		// display on
data.h
 * This file contains all the static arrays to draw things in the display.
// Tindie Logo
prog_uchar logo [] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80,
0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x00, 0x00, 0x00, 0xC0, 0xE0, 0xF8, 0x3C, 0x1C, 0x0E, 0x07,
0x07, 0x83, 0x83, 0x83, 0xC3, 0xC7, 0xEF, 0xFE, 0x7C, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x80, 0x80, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0x80, 0x80, 0x00,
0x00, 0x00, 0x00, 0xC0, 0xE0, 0xF0, 0x78, 0x1C, 0x1E, 0x0E, 0x07, 0x07, 0x1F, 0xFB, 0xAB, 0x83,
0x01, 0x01, 0x01, 0x01, 0x03, 0x03, 0x03, 0x07, 0x0F, 0x3F, 0xFF, 0xFC, 0x8E, 0x0E, 0x06, 0x07,
0x07, 0x03, 0x03, 0x01, 0x01, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x7E, 0xFF, 0xE7, 0xE1, 0xE1, 0xE0, 0xE0, 0x60, 0x60, 0x70, 0x71, 0x71, 0x71, 0x33, 0x37,
0x3F, 0x7E, 0xFF, 0xEF, 0x83, 0x00, 0x00, 0x80, 0xC0, 0xE0, 0xE0, 0xE0, 0xC0, 0x80, 0x03, 0x0E,
0x70, 0xC0, 0x00, 0x78, 0xFC, 0xCE, 0xC6, 0xC6, 0xFE, 0xFC, 0x31, 0x07, 0x3F, 0xFE, 0xF0, 0x00,
0x00, 0x00, 0x01, 0x0F, 0x7F, 0xFC, 0xE3, 0x8F, 0x1F, 0x18, 0x18, 0x1C, 0x0F, 0x0F, 0x00, 0x80,
0x80, 0x41, 0x6E, 0x38, 0x20, 0x11, 0x11, 0x11, 0x70, 0x10, 0x70, 0x10, 0xF0, 0xFF, 0xFF, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x10, 0xF0, 0xF0, 0x10, 0x10, 0x00, 0x00, 0xD8, 0xD8, 0x00,
0x00, 0xC0, 0xC0, 0x40, 0x40, 0xC0, 0x80, 0x00, 0x00, 0x80, 0xC0, 0x40, 0x40, 0xF8, 0xF8, 0x00,
0x00, 0xD8, 0xD8, 0x00, 0x00, 0x80, 0xC0, 0x40, 0x40, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x80, 0xC0, 0x40, 0x40, 0x80, 0x00, 0x80, 0xC0, 0x40, 0x40, 0xC0, 0x80, 0x00, 0x00, 0xC0,
0xC0, 0x40, 0x40, 0xC0, 0x80, 0x40, 0x40, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7C, 0xFE, 0xE7, 0xC7, 0xE7, 0x7E, 0x7C, 0x00, 0x00,
0x00, 0x00, 0x80, 0xE0, 0xF8, 0x7D, 0x1F, 0x87, 0xCF, 0xFE, 0xFC, 0xFC, 0xF4, 0xE2, 0xC1, 0x81,
0x00, 0x10, 0x18, 0x18, 0x1C, 0x1C, 0x9E, 0x8E, 0xC7, 0xC0, 0xE0, 0xF0, 0x7F, 0x3F, 0x1F, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x1F, 0x00,
0x00, 0x1F, 0x1F, 0x00, 0x00, 0x1F, 0x1F, 0x00, 0x00, 0x0F, 0x1F, 0x10, 0x10, 0x1F, 0x1F, 0x00,
0x00, 0x1F, 0x1F, 0x00, 0x00, 0x0F, 0x1F, 0x12, 0x12, 0x13, 0x0B, 0x00, 0x00, 0x18, 0x18, 0x00,
0x00, 0x0F, 0x1F, 0x10, 0x10, 0x08, 0x00, 0x0F, 0x1F, 0x10, 0x10, 0x1F, 0x0F, 0x00, 0x00, 0x1F,
0x1F, 0x00, 0x00, 0x1F, 0x1F, 0x00, 0x00, 0x1F, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x06, 0x0E, 0x0E, 0xFE, 0xFF, 0x0F, 0x7F, 0xFF, 0xF7, 0x87, 0x06, 0x00,
0xE0, 0xFE, 0xFF, 0x0F, 0x01, 0x00, 0x0F, 0x3F, 0x3F, 0x7F, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0x3F, 0x1E, 0x07, 0x07, 0x07, 0x03, 0x03, 0x03, 0x01, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xE7, 0x7F, 0x7E, 0x78, 0x31, 0x33, 0x3F, 0x3E, 0x7E,
0xFF, 0xEF, 0xC0, 0xE0, 0x60, 0x60, 0x70, 0x60, 0x60, 0xE0, 0xE0, 0xC0, 0x90, 0xE5, 0xFF, 0xC3,
0xE0, 0xE0, 0x60, 0x60, 0x70, 0x60, 0x60, 0xE0, 0xC0, 0xFF, 0xFF, 0x3F, 0x30, 0x30, 0x70, 0x70,
0xE0, 0xE0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x7E, 0x7F, 0x67, 0x61, 0x60, 0x60, 0x60, 0x60, 0x60, 0x60, 0x60, 0x78,
0x7F, 0x7F, 0x61, 0x60, 0x60, 0x60, 0x60, 0x60, 0x60, 0x60, 0x60, 0x61, 0x7F, 0x7F, 0x7F, 0x61,
0x60, 0x60, 0x60, 0x60, 0x60, 0x60, 0x60, 0x60, 0x61, 0x7F, 0x7F, 0x78, 0x60, 0x60, 0x60, 0x60,
0x60, 0x61, 0x67, 0x7F, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
// Globe Logo OLED Test
unsigned char logo[] PROGMEM = {
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x3F, 0x9F, 0xDF,
0xFF, 0xFF, 0xFF, 0x7F, 0x3F, 0x1F, 0x0F, 0x0F, 0x07, 0x07, 0x07, 0x07, 0x0F, 0x0F, 0x0F, 0x0F,
0x1F, 0x1F, 0x3F, 0x3C, 0x3C, 0x7C, 0x78, 0xF8, 0xF0, 0xF0, 0xE1, 0xC1, 0xC1, 0x83, 0x03, 0x03,
0x07, 0x07, 0x0F, 0x1F, 0x3F, 0x3F, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0x7F, 0x3F, 0x3F, 0x3F, 0x7F, 0xFF, 0xFF, 0xFF, 0x3F, 0x3F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x3F, 0x3F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x1F, 0x87, 0xE3, 0xF8, 0xFE, 0x3F, 0x3F, 0x3F,
0x3F, 0x3F, 0x3F, 0x3C, 0x3C, 0x3C, 0x3C, 0x3C, 0x3C, 0x38, 0x78, 0x78, 0x78, 0x70, 0xF0, 0xF0,
0xE0, 0xE0, 0xE0, 0xC0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x01, 0x03, 0x03, 0x07, 0x0F, 0x1F, 0x3F,
0x7E, 0xFC, 0xF8, 0xF0, 0xE0, 0xC0, 0x80, 0x00, 0x01, 0x07, 0x0F, 0x3F, 0xFF, 0xFF, 0xFF, 0xFF,
0xF0, 0xE0, 0xCF, 0xCF, 0xCF, 0xE0, 0xF0, 0xFF, 0xFF, 0xC0, 0xC0, 0xFF, 0xFF, 0xE1, 0xC0, 0xCA,
0xC8, 0xE9, 0xFF, 0xFF, 0xE1, 0xC0, 0xCC, 0xC0, 0xC0, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x07, 0x00, 0xFC, 0xFF, 0xFF, 0x07, 0x80, 0xC0, 0xC0, 0xC0,
0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xC0, 0xC0, 0xC0, 0x80, 0x80, 0x80, 0x00, 0x00,
0x01, 0x01, 0x03, 0x07, 0x07, 0x0F, 0x1F, 0x3F, 0x7E, 0xFC, 0xF8, 0xF0, 0xE0, 0xC0, 0x00, 0x00,
0x00, 0x00, 0x01, 0x03, 0x07, 0x1F, 0x3F, 0xFE, 0xFC, 0xF0, 0xE0, 0x80, 0x00, 0x03, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x80, 0x00, 0xFF, 0xFF, 0xFF, 0x80, 0x03, 0x03, 0x03, 0x03,
0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x03, 0x03, 0x07, 0x07, 0x0F, 0x0F, 0x1F, 0x3E,
0x7E, 0xFC, 0xF8, 0xF0, 0xE0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x01, 0x03, 0x0F, 0x3F, 0xFF, 0xFE,
0xF8, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x1F, 0xFF, 0xFF, 0xFE, 0xF8, 0xFC, 0xFF,
0xFF, 0xFF, 0x9F, 0x9F, 0x1F, 0x1F, 0x9F, 0x9F, 0xFF, 0xFF, 0xFF, 0x7F, 0x7F, 0x7F, 0xFF, 0xFF,
0xFF, 0xFF, 0x7F, 0x7F, 0x7F, 0xFF, 0xFF, 0x7F, 0x3F, 0x1F, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF8, 0xE0, 0x87, 0x1F, 0x7F, 0xFE, 0xFC, 0xFC, 0xFE,
0x7E, 0x3E, 0x1E, 0x1F, 0x1F, 0x3E, 0x7E, 0xFE, 0xFC, 0xFC, 0xF8, 0xF0, 0xC0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x03, 0x0F, 0x7F, 0xFF, 0xFE, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07,
0xFF, 0xFF, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xE0, 0xE0, 0xFF, 0xFF, 0xFF, 0xFF, 0xF0, 0xE0, 0xE5, 0xE4, 0xF4, 0xFF,
0xFF, 0xF4, 0xEC, 0xE9, 0xE1, 0xF2, 0xFF, 0xFE, 0xE0, 0xE0, 0xE6, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFC, 0xF9, 0xF3, 0xC7, 0x8D,
0x80, 0x20, 0x60, 0xE0, 0xE0, 0xE0, 0xF0, 0xF8, 0xFF, 0xFF, 0xFF, 0x7F, 0x0F, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x80, 0xF0, 0xFF, 0xFF, 0xFF, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80,
0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0xFC, 0x7C, 0x7C, 0x3E, 0xBF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFE, 0xFC, 0xFD, 0xF9, 0xFB, 0xF3, 0xF7, 0xE7, 0xE7, 0xEF, 0xCF, 0xCE, 0xDE, 0xDC,
0x9C, 0x9C, 0x9E, 0x9F, 0x9F, 0x9F, 0x9F, 0x9F, 0x9E, 0xDE, 0xDE, 0xCE, 0xCE, 0xEE, 0xE7, 0xE7,
0xF7, 0xF3, 0xFB, 0xF9, 0xFD, 0xFC, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
//Intel Logo
0x00, 0x00, 0x00, 0x80, 0xC0, 0xC0, 0xC0, 0xE0, 0xF0, 0xF0, 0x78, 0x78, 0x7C, 0x7C, 0x7C, 0x7C,
0x3C, 0x3C, 0x3C, 0x3C, 0x3C, 0x3C, 0x3C, 0x3C, 0x3C, 0x7C, 0x7C, 0x7C, 0x7C, 0xF8, 0xF8, 0xF0,
0xE0, 0xC0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x38, 0x3C,
0x1E, 0x0E, 0x0F, 0x07, 0x03, 0x03, 0x03, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0x81, 0x03,
0x03, 0x0F, 0x3F, 0xFF, 0xFE, 0xFC, 0xF0, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80,
0xE0, 0xE0, 0x70, 0x70, 0x38, 0x38, 0x38, 0x70, 0xF0, 0xE0, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xF0, 0xF0, 0x00, 0x00, 0xF8, 0xF8,
0x00, 0x00, 0x00, 0xF0, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xF0, 0xF8, 0x3C, 0x00, 0xCF, 0xCF, 0xCF, 0x00, 0x00, 0xC0,
0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0x80, 0x00, 0x00, 0xFE, 0xFE, 0xFE, 0xFE, 0xC0, 0xC0,
0x00, 0x00, 0x80, 0xC0, 0xC0, 0xC0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0xFF,
0x07, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0xE0, 0xE0,
0x60, 0x70, 0x60, 0xE0, 0xE0, 0xC0, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0xE3, 0xE3,
0x00, 0x00, 0x00, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0xE0, 0xE0, 0xE0, 0x70, 0x60, 0xE0, 0xE0,
0xC0, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xE0, 0xE0, 0x60, 0x70, 0x70, 0xE0, 0xE0, 0xE0, 0x80, 0x00,
0x00, 0x00, 0xC0, 0xFC, 0xFF, 0x7F, 0x07, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0xFF,
0xFF, 0xFF, 0xFF, 0x07, 0x07, 0xFF, 0xFF, 0xFF, 0xFC, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x07, 0xC7,
0xFE, 0xFF, 0xFF, 0xFF, 0xE7, 0xEF, 0xFF, 0xFF, 0xFF, 0xF8, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x00,
0x00, 0x00, 0x80, 0xF0, 0xFF, 0xFF, 0xFF, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0,
0xC0, 0xC0, 0xE0, 0xE0, 0xE3, 0xFF, 0xFF, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0xFF, 0xFF,
0x00, 0x00, 0x00, 0xFF, 0xFF, 0x00, 0x00, 0xF8, 0xFF, 0xFF, 0x81, 0x80, 0x80, 0x80, 0x80, 0x81,
0xFF, 0xFF, 0xF0, 0x00, 0xFF, 0xFF, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x1F, 0xFF, 0xFC,
0x00, 0x00, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0xFF,
0xFF, 0xFF, 0xFF, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xF0, 0xF1,
0x3F, 0xFF, 0xFF, 0xFF, 0xF3, 0xF3, 0xF3, 0xFB, 0xF3, 0x63, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xF8,
0xFC, 0xFF, 0x7F, 0x3F, 0x1F, 0x07, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xFF,
0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0x00, 0x00, 0xF8, 0xFF, 0xFF, 0x03,
0x01, 0x01, 0x01, 0x01, 0x01, 0xFF, 0xFF, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0xFF, 0xFF,
0x00, 0x00, 0x00, 0xFF, 0xFF, 0x00, 0x00, 0x3F, 0xFF, 0xFD, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01,
0x01, 0x01, 0x01, 0x00, 0xFF, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xFF, 0x7F,
0x00, 0x00, 0x0F, 0xFF, 0xFF, 0xFF, 0xF8, 0xC0, 0x80, 0x00, 0x00, 0x01, 0x01, 0x00, 0x00, 0x01,
0x01, 0x01, 0x01, 0x00, 0x00, 0x01, 0x01, 0x01, 0x01, 0x00, 0x00, 0x01, 0x01, 0x01, 0x01, 0x01,
0x00, 0x00, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x80, 0x80, 0xC0, 0xE1, 0xF1, 0xF9, 0xF9,
0x01, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x07, 0x0F, 0x0F, 0x0E, 0x1C, 0x1C, 0x1C, 0x0C, 0x0F, 0x0F, 0x00, 0x00, 0x00, 0x07, 0x0F, 0x0E,
0x0C, 0x1C, 0x1C, 0x0C, 0x0C, 0x0F, 0x0F, 0x00, 0x00, 0x0F, 0x0F, 0x0F, 0x00, 0x00, 0x0F, 0x0F,
0x00, 0x00, 0x00, 0x0F, 0x0F, 0x00, 0x00, 0x00, 0x01, 0x0F, 0x0F, 0x0E, 0x1C, 0x1C, 0x1C, 0x0E,
0x0E, 0x0F, 0x00, 0x00, 0x01, 0x07, 0x0F, 0x0E, 0x1C, 0x1C, 0x1C, 0x0E, 0x0F, 0x0F, 0x03, 0x00,
0x00, 0x00, 0x00, 0x00, 0x03, 0x0F, 0x1F, 0x7F, 0xFF, 0xFF, 0xFE, 0xFC, 0xF8, 0xF8, 0xF0, 0xF0,
0xF0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xF0, 0xF0, 0xF0,
0xF8, 0xF8, 0xF8, 0xF8, 0xFC, 0xFC, 0xFE, 0xFF, 0xFF, 0xFF, 0x7F, 0x3F, 0x3F, 0x1F, 0x0F, 0x07,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x03, 0x07, 0x07, 0x07, 0x07,
0x07, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x07, 0x07,
0x07, 0x07, 0x07, 0x07, 0x03, 0x01, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
// Big numbers font, from 0 to 9. 96 byte each.
prog_uchar bigNumbers [][96] PROGMEM = {
{0x00, 0x00, 0x00, 0xC0, 0xE0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0,
0xF0, 0xF0, 0xF0, 0xE0, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x01,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x80, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x07, 0x0F, 0x0F, 0x0F,
0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x07, 0x03, 0x00, 0x00, 0x00},
{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0xF0,
0xF0, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF,
0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x07, 0x07, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
{0x00, 0x00, 0x00, 0xE0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0,
0xF0, 0xF0, 0xF0, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x81, 0xC1, 0xC0, 0xC0, 0xC0,
0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xE1, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x87, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03,
0x03, 0x03, 0x83, 0x81, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x0F, 0x0F, 0x0F, 0x0F,
0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x07, 0x00, 0x00, 0x00, 0x00},
0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xE1, 0xFF, 0xFF, 0xFF, 0x7F, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x81, 0x83, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x87,
0xFF, 0xFF, 0xFF, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x0F, 0x0F, 0x0F, 0x0F,
{0x00, 0x00, 0x00, 0xE0, 0xF0, 0xF0, 0xF0, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30,
0xF0, 0xF0, 0xF0, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xE0,
0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xE0, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x01, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x07,
0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x0F, 0x0F, 0x0F, 0x07, 0x00, 0x00, 0x00, 0x00},
0xF0, 0xF0, 0xF0, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xE1,
0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC1, 0x81, 0x00, 0x00, 0x00, 0x00,
0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x0F, 0x0F, 0x0F, 0x0F,
0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x87, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x87,
0xF0, 0xF0, 0xF0, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x01, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00,
0xF0, 0xF0, 0xF0, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xFF, 0xFF, 0xFF, 0xE1,
0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xE1, 0xFF, 0xFF, 0xFF, 0x3F, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0xFE, 0xFF, 0xFF, 0xFF, 0x87, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x87,
{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x3C, 0x7E, 0x7E, 0x7E, 0x7E, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xF8, 0xF8, 0xF8, 0xF8, 0xF0, 0x00,
0x00, 0x00, 0x01, 0x01, 0x01, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}
// Big numbers minus simbol.
prog_uchar minus [] PROGMEM = {
0x00, 0x00, 0x0C, 0x1E, 0x1E, 0x1E, 0x1E, 0x1E, 0x1E, 0x1E, 0x1E, 0x1E, 0x1E, 0x1E, 0x1E, 0x1E,
0x1E, 0x1E, 0x1E, 0x1E, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
// Km/h in big font. This avoids to create an entirely new big font and saves flash space.
prog_uchar kmh [] PROGMEM = {
0x00, 0x00, 0xC0, 0xC0, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0xE0, 0x00, 0x80,
0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xF0, 0xF8, 0xFC,
0x9E, 0x0E, 0x06, 0xE0, 0xF0, 0xF0, 0xF0, 0x70, 0xF0, 0xE0, 0xF0, 0xF0, 0x70, 0xF0, 0xE0, 0xC0,
0x00, 0x00, 0xE0, 0xFE, 0x1F, 0x01, 0x00, 0xFF, 0xFF, 0xFF, 0x18, 0x18, 0xF8, 0xF0, 0xF0, 0x00,
0x00, 0x00, 0x07, 0x07, 0x07, 0x00, 0x01, 0x03, 0x07, 0x07, 0x06, 0x07, 0x07, 0x07, 0x00, 0x00,
0x07, 0x07, 0x07, 0x00, 0x00, 0x07, 0x07, 0x07, 0x00, 0x1E, 0x1F, 0x01, 0x00, 0x00, 0x00, 0x07,
// degrees, outside the ascii table myFont
prog_uchar myDregree [8] PROGMEM = {
0x00,0x00,0x0C,0x12,0x12,0x0C,0x00,0x00
// Small 8x8 font
unsigned char myFont[][8]={
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0x5F,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0x07,0x00,0x07,0x00,0x00,0x00},
{0x00,0x14,0x7F,0x14,0x7F,0x14,0x00,0x00},
{0x00,0x24,0x2A,0x7F,0x2A,0x12,0x00,0x00},
{0x00,0x23,0x13,0x08,0x64,0x62,0x00,0x00},
{0x00,0x36,0x49,0x55,0x22,0x50,0x00,0x00},
{0x00,0x00,0x05,0x03,0x00,0x00,0x00,0x00},
{0x00,0x1C,0x22,0x41,0x00,0x00,0x00,0x00},
{0x00,0x41,0x22,0x1C,0x00,0x00,0x00,0x00},
{0x00,0x08,0x2A,0x1C,0x2A,0x08,0x00,0x00},
{0x00,0x08,0x08,0x3E,0x08,0x08,0x00,0x00},
{0x00,0xA0,0x60,0x00,0x00,0x00,0x00,0x00},
{0x00,0x08,0x08,0x08,0x08,0x08,0x00,0x00},
{0x00,0x60,0x60,0x00,0x00,0x00,0x00,0x00},
{0x00,0x20,0x10,0x08,0x04,0x02,0x00,0x00},
{0x00,0x3E,0x51,0x49,0x45,0x3E,0x00,0x00},
{0x00,0x00,0x42,0x7F,0x40,0x00,0x00,0x00},
{0x00,0x62,0x51,0x49,0x49,0x46,0x00,0x00},
{0x00,0x22,0x41,0x49,0x49,0x36,0x00,0x00},
{0x00,0x18,0x14,0x12,0x7F,0x10,0x00,0x00},
{0x00,0x27,0x45,0x45,0x45,0x39,0x00,0x00},
{0x00,0x3C,0x4A,0x49,0x49,0x30,0x00,0x00},
{0x00,0x01,0x71,0x09,0x05,0x03,0x00,0x00},
{0x00,0x36,0x49,0x49,0x49,0x36,0x00,0x00},
{0x00,0x06,0x49,0x49,0x29,0x1E,0x00,0x00},
{0x00,0x00,0x36,0x36,0x00,0x00,0x00,0x00},
{0x00,0x00,0xAC,0x6C,0x00,0x00,0x00,0x00},
{0x00,0x08,0x14,0x22,0x41,0x00,0x00,0x00},
{0x00,0x14,0x14,0x14,0x14,0x14,0x00,0x00},
{0x00,0x41,0x22,0x14,0x08,0x00,0x00,0x00},
{0x00,0x02,0x01,0x51,0x09,0x06,0x00,0x00},
{0x00,0x32,0x49,0x79,0x41,0x3E,0x00,0x00},
{0x00,0x7E,0x09,0x09,0x09,0x7E,0x00,0x00},
{0x00,0x7F,0x49,0x49,0x49,0x36,0x00,0x00},
{0x00,0x3E,0x41,0x41,0x41,0x22,0x00,0x00},
{0x00,0x7F,0x41,0x41,0x22,0x1C,0x00,0x00},
{0x00,0x7F,0x49,0x49,0x49,0x41,0x00,0x00},
{0x00,0x7F,0x09,0x09,0x09,0x01,0x00,0x00},
{0x00,0x3E,0x41,0x41,0x51,0x72,0x00,0x00},
{0x00,0x7F,0x08,0x08,0x08,0x7F,0x00,0x00},
{0x00,0x41,0x7F,0x41,0x00,0x00,0x00,0x00},
{0x00,0x20,0x40,0x41,0x3F,0x01,0x00,0x00},
{0x00,0x7F,0x08,0x14,0x22,0x41,0x00,0x00},
{0x00,0x7F,0x40,0x40,0x40,0x40,0x00,0x00},
{0x00,0x7F,0x02,0x0C,0x02,0x7F,0x00,0x00},
{0x00,0x7F,0x04,0x08,0x10,0x7F,0x00,0x00},
{0x00,0x3E,0x41,0x41,0x41,0x3E,0x00,0x00},
{0x00,0x7F,0x09,0x09,0x09,0x06,0x00,0x00},
{0x00,0x3E,0x41,0x51,0x21,0x5E,0x00,0x00},
{0x00,0x7F,0x09,0x19,0x29,0x46,0x00,0x00},
{0x00,0x26,0x49,0x49,0x49,0x32,0x00,0x00},
{0x00,0x01,0x01,0x7F,0x01,0x01,0x00,0x00},
{0x00,0x3F,0x40,0x40,0x40,0x3F,0x00,0x00},
{0x00,0x1F,0x20,0x40,0x20,0x1F,0x00,0x00},
{0x00,0x3F,0x40,0x38,0x40,0x3F,0x00,0x00},
{0x00,0x63,0x14,0x08,0x14,0x63,0x00,0x00},
{0x00,0x03,0x04,0x78,0x04,0x03,0x00,0x00},
{0x00,0x61,0x51,0x49,0x45,0x43,0x00,0x00},
{0x00,0x7F,0x41,0x41,0x00,0x00,0x00,0x00},
{0x00,0x02,0x04,0x08,0x10,0x20,0x00,0x00},
{0x00,0x41,0x41,0x7F,0x00,0x00,0x00,0x00},
{0x00,0x04,0x02,0x01,0x02,0x04,0x00,0x00},
{0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00},
{0x00,0x01,0x02,0x04,0x00,0x00,0x00,0x00},
{0x00,0x20,0x54,0x54,0x54,0x78,0x00,0x00},
{0x00,0x7F,0x48,0x44,0x44,0x38,0x00,0x00},
{0x00,0x38,0x44,0x44,0x28,0x00,0x00,0x00},
{0x00,0x38,0x44,0x44,0x48,0x7F,0x00,0x00},
{0x00,0x38,0x54,0x54,0x54,0x18,0x00,0x00},
{0x00,0x08,0x7E,0x09,0x02,0x00,0x00,0x00},
{0x00,0x18,0xA4,0xA4,0xA4,0x7C,0x00,0x00},
{0x00,0x7F,0x08,0x04,0x04,0x78,0x00,0x00},
{0x00,0x00,0x7D,0x00,0x00,0x00,0x00,0x00},
{0x00,0x80,0x84,0x7D,0x00,0x00,0x00,0x00},
{0x00,0x7F,0x10,0x28,0x44,0x00,0x00,0x00},
{0x00,0x41,0x7F,0x40,0x00,0x00,0x00,0x00},
{0x00,0x7C,0x04,0x18,0x04,0x78,0x00,0x00},
{0x00,0x7C,0x08,0x04,0x7C,0x00,0x00,0x00},
{0x00,0x38,0x44,0x44,0x38,0x00,0x00,0x00},
{0x00,0xFC,0x24,0x24,0x18,0x00,0x00,0x00},
{0x00,0x18,0x24,0x24,0xFC,0x00,0x00,0x00},
{0x00,0x00,0x7C,0x08,0x04,0x00,0x00,0x00},
{0x00,0x48,0x54,0x54,0x24,0x00,0x00,0x00},
{0x00,0x04,0x7F,0x44,0x00,0x00,0x00,0x00},
{0x00,0x3C,0x40,0x40,0x7C,0x00,0x00,0x00},
{0x00,0x1C,0x20,0x40,0x20,0x1C,0x00,0x00},
{0x00,0x3C,0x40,0x30,0x40,0x3C,0x00,0x00},
{0x00,0x44,0x28,0x10,0x28,0x44,0x00,0x00},
{0x00,0x1C,0xA0,0xA0,0x7C,0x00,0x00,0x00},
{0x00,0x44,0x64,0x54,0x4C,0x44,0x00,0x00},
{0x00,0x08,0x36,0x41,0x00,0x00,0x00,0x00},
{0x00,0x00,0x7F,0x00,0x00,0x00,0x00,0x00},
{0x00,0x41,0x36,0x08,0x00,0x00,0x00,0x00},
{0x00,0x02,0x01,0x01,0x02,0x01,0x00,0x00},
{0x00,0x02,0x05,0x05,0x02,0x00,0x00,0x00}
// File generated by LCD Assistant
// http://www.wide.hk
SSD1306_ESP8266.ino
 * Arduino IDE 1.6.7 on Linux Mint 17.3 tested on 20160204
 *  Sketch uses 229,448 bytes (52%) of program storage space. Maximum is 434,160 bytes.
 *  Global variables use 31,877 bytes (38%) of dynamic memory, leaving 50,043 bytes for local variables.
#include <Wire.h>
#include "./data.h"               // FONT + GRAPHIC
#include "./SSD1306.h"
#define Pin_SDA 0
#define Pin_SCL 2
// #define OLED_Address 0x3c --> See Tab SSD1306.h
  Wire.pins(Pin_SDA, Pin_SCL);              //0=SDA, 2=SCL, 2 also =LED
  Wire.begin();                 // Initialize I2C and OLED Display
  init_OLED();
  reset_display();              // Clear logo and load saved mode
  for (int i = 0; i < 128 * 8; i++) // display Logo
    SendChar(pgm_read_byte(logo + i));
    delay(8000);
    displayOn();
    clear_display();
    while (1)
      sendStrXY("Oled on", 3, 0);
      sendStrXY("ESP8266 only!", 4, 0);
      delay(4000);
      reset_display();
      clear_display();
      reset_display();
Full Zip attached with blobs ... all in single folder
ESP_I2C_OLED_1.zip (8.2 KB)
