i have a string that is
String a = "water".
i want to transfer it with softwareserial from nodemcu to arduino.
how can i complete this code for that?
#include <SoftwareSerial.h>
SoftwareSerial s(D6, D5);
String a = "water"
void setup ()
s.begin(9600);
void loop ()
//???? what should i write here?
s.write(a); // is this correct?
Have you tested your posted sketch having done a physical connection between NodeMCU and UNO? If yes, what is the result? Can you observe the string on the Serial Monitor of the UNO? Where is your receiver sketch?
GolamMostafa:
you mean this sender code is right hah?
but i get this error :
no matching function for call to SoftwareSerial::write(String&)
TheMemberFormerlyKnownAsAWOL:
Serial.print(a);
now we arrive to main problem. i used this s.print(a).
i replace a to "200water". but when i get it in arduino side, it show me = "00water". where is the problem?
my arduino code is here:
String a = "200water"
void setup ()
Serial1.begin(9600);
void loop ()
while (!Serial1.available()) {delay (500);}
if (Serial1.read() > 0)
while (Serial1.available())
reading = Serial1.read();
inchar += reading;
delay (1);
Serial.println(inchar); // it prints "00water"!!!!}
Which Arduino?
Search for Robin's "serial input basics - updated" thread to get ideas how to reliably receive data.
sterretje:
Which Arduino?
this is nodemcu that want to send "200water":
String a = "water"
void setup ()
s.begin(9600);
void loop ()
this is arduino that want to get "200water" but it get "00water":
void setup ()
void loop ()
inchar += reading;
delay (1);
This code is reading the first byte from the message and throwing it away.
Instead, use Serial.avaliable()
if (Serial1.available() > 0)
The best approach would be to use the more memory efficient char array instead of "S"tring coupled with a robust serial packet protocol. You can use SerialTransfer.h to automatically implement such a protocol for inter-Arduino communication without the headace. The library is installable through the Arduino IDE and includes many examples.
Here are the library's features:
This library:
- can be downloaded via the Arduino IDE's Libraries Manager (search "SerialTransfer.h")
- works with "software-serial" libraries
- is non blocking
- uses packet delimiters
- uses consistent overhead byte stuffing
- uses CRC-8 (Polynomial 0x9B with lookup table)
- allows the use of dynamically sized packets (packets can have payload lengths anywhere from 1 to 254 bytes)
- can transfer bytes, ints, floats, and even structs!!
Example TX Arduino Sketch:
#include "SerialTransfer.h"
SerialTransfer myTransfer;
Serial1.begin(115200);
myTransfer.begin(Serial1);
char buff[] = "hi";
myTransfer.txObj(buff, sizeof(buff));
myTransfer.sendData(sizeof(buff));
delay(100);
Example RX Arduino Sketch:
if(myTransfer.available())
char buff[40];
myTransfer.rxObj(buff, sizeof(buff));
Serial.println("New Data: ");
Serial.write(buff, sizeof(buff));
else if(myTransfer.status < 0)
Serial.print("ERROR: ");
if(myTransfer.status == -1)
Serial.println(F("CRC_ERROR"));
else if(myTransfer.status == -2)
Serial.println(F("PAYLOAD_ERROR"));
else if(myTransfer.status == -3)
Serial.println(F("STOP_BYTE_ERROR"));
For theory behind robust serial communication, check out the tutorials Serial Input Basics and Serial Input Advanced.
cattledog:
so tnx guys. this solved.
