Im using PLX-DAQ to transfer data from EEPROM to excel, but I encountered a problem while writing data to Excel via PLX-DAQ. I want to use ( “CELL,SET,B2,”, DEC x, ) command. Normally, i can read with arduino serial monitor with ( Serial.println(readEEPROM(disk1, address), DEC); ) command but i place this data to Cell Set command, it is not working. red line gives the error, and help of the plx-daq says that Sets the specified cell value or text with “DEBUG “CELL,SET,B4,Hello!”,CR
DEBUG “CELL,SET,B5,”, DEC x, CR” commands.
code is ;
#include <Wire.h>
#define disk1 0x50
const int checkpin1 = 41;
const int checkpin2 = 42;
const int checkpin3 = 43;
const int checkpin4 = 44;
const int selectpin0 = 23;
const int selectpin1 = 22;
int pinState1 = 0;
int pinState2 = 0;
int pinState3 = 0;
int pinState4 = 0;
void setup(void)
pinMode(checkpin1, INPUT);
pinMode(checkpin2, INPUT);
pinMode(checkpin3, INPUT);
pinMode(checkpin4, INPUT);
pinMode(selectpin0, OUTPUT);
pinMode(selectpin1, OUTPUT);
Serial.println(“CLEARDATA”);
Serial.println(“LABEL,SLOT NO,MODUL ID”);
Wire.begin();
unsigned int address = 0;
// Serial.print(readEEPROM(disk1, address), DEC);
pinState1 = digitalRead(checkpin1);
pinState2 = digitalRead(checkpin2);
pinState3 = digitalRead(checkpin3);
pinState4 = digitalRead(checkpin4);
if (pinState1 == HIGH)
digitalWrite(selectpin0, LOW);
digitalWrite(selectpin1, LOW);
Wire.begin();
Serial.println(“CELL,SET,A2,SLOT 1”);
Serial.println(“CELL,SET,B2,”,DEC readEEPROM(disk1, address));
byte readEEPROM(int deviceaddress, unsigned int eeaddress )
byte rdata = 0xFF;
Wire.beginTransmission(deviceaddress);
Wire.write((int)(eeaddress >> 8)); // MSB
Wire.write((int)(eeaddress & 0xFF)); // LSB
Wire.endTransmission();
Wire.requestFrom(deviceaddress,1);
if (Wire.available()) rdata = Wire.read();
return rdata;
