How to translate a String or Char into a Byte or a uint16_t
Hi everyone,
I got stuck in a problem. I'm working with (example: 0xFF03) codes for my Infra Red light strips. In my code I want to Serial send the addres (example: 0x2) to turn my LED strips OFF. I got so far to get full Strings trough my serial monitor. So if I send: 0x2, the program would recognise the "0x" at the beginning. Also he turns the value after the "0x" into a "int" and with a snprintf() function he sticks the "0x" in front of it, but then it turns into a "char".
Can anyone help me with a function to write ether the "String" version or the "Char" version of my "0x2" code into a "Byte" or a "uint16_t"? See my code below...
#include <Arduino.h>
#include "PinDefinitionsAndMore.h"
#include <IRremote.h>
String data;
byte code = 0;
    for(int i=9; i<=12; i++){
      pinMode(i, OUTPUT);
    IrSender.begin(IR_SEND_PIN, ENABLE_LED_FEEDBACK);
//IrSender.sendNEC(sAddress, 0x2, sRepeats);
uint16_t sAddress = 0xEF00;
uint8_t sRepeats = 0;
byte test = 0x2;
void loop(){
  while(Serial.available()){
    delay(3);
    char c = Serial.read();
    data += c;
  if(data.length() > 0){
    Switch(data.substring(0, 1).toInt(), data.substring(1));
    if(data.substring(0, 2) == "0x"){
      //char val[20];
      //int input = data.substring(2).toInt();
      //snprintf(val, sizeof(val), "0x%X", input);
      Serial.println(val, HEX);
      IrSender.sendNEC(sAddress, (val, HEX), sRepeats);
    data = "";
void Switch(int numb, String state){
  int pin = numb + 8;
  int intState;
  if(state == "on" || state == "ON"){
    digitalWrite(pin, HIGH);
  if(state == "off" || state == "OFF"){
    digitalWrite(pin, LOW);
I would suggest to study Serial Input Basics to handle this
For decimal numbers:
int atoi( const char *str );
long atol( const char *str );
For other bases, like hex:
long strtol( const char *str, char **str_end, int base );
If you set 'base' to 0 it will read the "0x" prefix and use hex.
If you pass a "char **str_end" it will set *str_end to point to the first character after the number.
And that helps you decide if the parsing was ok as you can’t tell if a 0 from atol() or atoi() is because the number to read was 0 or the parsing failed.
So strtol() is a good option if that’s important
Thanks mr. John Wasser. It worked for me!
It's actually always the better option in my opinion if one does not validate received data before converting :wink:
