How to transmit words from a RF transmitter and catch them with the Receiver?
I'm trying to transmit a word from the Rf Transmitter and Receiver. I successfully transmitted a one letter through. Then tried to transmit a word.
char input = "hello";
    send(&input);
It says warning: invalid conversion from 'const char*' to 'char' [-fpermissive]
char input = "gg";
I used virtual-Wire Library.
Mainly i need to send a number not a word. Is there a way to do it without sending a word?
send(&input);
This is not a valid call to the VirtualWire library.
The standard call to send a character string is the following:
   vw_send((uint8_t *)msg, strlen(msg));
However, you can send anything you like as long as you cast it correctly. To send a 2 byte integer, use:
   int x=1210;
    vw_send((uint8_t *)&x, 2);
Of course you will need to modify the receive code to expect an integer.
What can you store in a char?
What can you store in a char ARRAY?
What are you trying to store?
What do you need to use to store that data?
