How to trigger a Relay AND turn on an external LED with the same output pin.
Goal - Use a single Arduino pin to turn on a Relay(energize it's coil) while simultaneously turning on an Indictor LED located on a separate panel.
Problem - digitalWrite(pinout, HIGH) turns on the LED but turns off the Relay.
digitalWrite(pinout, LOW) turns off the LED while turning on the Relay.
note: I am using the NC connections of the RELAY.
Can I Turn on the relay AND the LED utilizing the same pin?
Yes. Just connect the led + series resistor between 5V and the pin.
I assume you are using a relay module, with a transistor or opto-isolator, rather than a bare relay? An Arduino pin cannot provide enough current to energise a relay's coil directly, and could be damaged.
Thanks SO much!
I spent a day trying to figure out how to make this work by myself. :confused:
