How to troubleshoot .cpp and .h files
Context:
In the process of making this Small Hexapod
For moving the servos, I am using this ArduSnake Library.
Problem:
I compiled the ArduSnake Library Example file Oscillator_serial_1
but getting errors in the .cpp and .h library files
Oscillator_serial_1 (Library Example File):
#include <Servo.h>
#include <Oscillator.h>
//-- Serial commands
const unsigned char CMD_STOP = 'S';  //-- Stop the oscilaltor
const unsigned char CMD_PLAY = 'P';  //-- Play the oscillator
//-- Declare two oscillators
Oscillator osc;
  //-- Configure the serial comunication with PC
  //-- Attach the oscillator to servo
  osc.attach(8);
  //-- Initially the oscillator is stoped
  osc.Stop();
  //-- The oscillator is configured with the default parameters
//-- Incoming byte from the PC
unsigned char inbyte;
  //-- refresh the oscillator
  osc.refresh();
  //-- When a byte is received from the PC
  if (Serial.available()) {
    //-- Read the byte and modify the oscillator state
    //-- acording to the command received
    inbyte = Serial.read();
    switch(inbyte){
      case CMD_STOP:     //-- Stop command
        osc.Stop();
      case CMD_PLAY:     //-- Play command
        osc.Play();
Error Seen on Arduino IDE:
In file included from C:\Users\Dielectric\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.3\cores\arduino/WCharacter.h:23:0,
                 from C:\Users\Dielectric\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.3\cores\arduino/Arduino.h:179,
                 from C:\Program Files (x86)\Arduino\libraries\ArduSnake\Oscillator.cpp:9:
C:\Program Files (x86)\Arduino\libraries\ArduSnake\Oscillator.h:54:12: error: expected unqualified-id before numeric constant
     double _N;        //-- Number of samples
C:\Program Files (x86)\Arduino\libraries\ArduSnake\Oscillator.cpp: In member function 'void Oscillator::attach(int, bool)':
C:\Program Files (x86)\Arduino\libraries\ArduSnake\Oscillator.cpp:48:6: error: lvalue required as left operand of assignment
   _N = _T/_TS;
C:\Program Files (x86)\Arduino\libraries\ArduSnake\Oscillator.cpp: In member function 'void Oscillator::SetT(unsigned int)':
C:\Program Files (x86)\Arduino\libraries\ArduSnake\Oscillator.cpp:73:6:error: lvalue required as left operand of assignment
   _N = _T/_TS;
Error compiling.
.cpp file & .h file:
--> Oscillator.cpp file
#if defined(ARDUINO) && ARDUINO >= 100
  #include "Arduino.h"
#else
  #include "WProgram.h"
  #include <pins_arduino.h>
#endif
#include "Oscillator.h"
#include <Servo.h>
//-- This function returns true if another sample
//-- should be taken (i.e. the TS time has passed since
//-- the last sample was taken
bool Oscillator::next_sample()
  //-- Read current time
  _currentMillis = millis();
  //-- Check if the timeout has passed
  if(_currentMillis - _previousMillis > _TS) {
    _previousMillis = _currentMillis;
    return true;
  return false;
//-- Attach an oscillator to a servo
//-- Input: pin is the arduino pin were the servo
//-- is connected
void Oscillator::attach(int pin, bool rev)
  //-- Attach the servo and move it to the home position
  _servo.attach(pin);
  _servo.write(90);
  //-- Initialization of oscilaltor parameters
  _TS=30;
  _T=2000;
  _N =_T/_TS;
  _inc = 2*M_PI/_N;
  _previousMillis=0;
  //-- Default parameters
  _A=45;
  _phase=0;
  _phase0=0;
  _O=0;
  _stop=false;
  //-- Reverse mode
  _rev = rev;
/* Set the oscillator period, in ms  */
void Oscillator::SetT(unsigned int T)
  //-- Assign the new period
  _T=T;
  //-- Recalculate the parameters
  _N = (double)_T/(double)_TS;
  _inc = 2*M_PI/_N;
/* Manual set of the position  */
void Oscillator::SetPosition(int position)
  _servo.write(position+_trim);
/* This function should be periodically called                     */
/* in order to maintain the oscillations. It calculates            */
/* if another sample should be taken and position the servo if so  */
void Oscillator::refresh()
  //-- Only When TS milliseconds have passed, the new sample is obtained
  if (next_sample()) {
      //-- If the oscillator is not stopped, calculate the servo position
      if (!_stop) {
        //-- Sample the sine function and set the servo pos
        _pos = round(_A * sin(_phase + _phase0) + _O);
	if (_rev) _pos=-_pos;
        _servo.write(_pos+90+_trim);
      //-- Increment the phase
      //-- It is always increased, even when the oscillator is stop
      //-- so that the coordination is always kept
      _phase = _phase + _inc;
-->Oscillator.h file
#ifndef Oscillator_h
#define Oscillator_h
#include <Servo.h>
//-- Macro for converting from degrees to radians
#ifndef DEG2RAD
  #define DEG2RAD(g) ((g)*M_PI)/180
#endif
class Oscillator
  public:
    Oscillator(int trim=0) {_trim=trim;};
    void attach(int pin, bool rev =false);
    void SetA(unsigned int A) {_A=A;};
    void SetO(unsigned int O) {_O=O;};
    void SetPh(double Ph) {_phase0=Ph;};
    void SetT(unsigned int T);
    void SetTrim(int trim){_trim=trim;};
    int getTrim() {return _trim;};
    void SetPosition(int position);
    void Stop() {_stop=true;};
    void Play() {_stop=false;};
    void Reset() {_phase=0;};
    void refresh();
  private:
    bool next_sample();
  private:
    //-- Servo that is attached to the oscillator
    Servo _servo;
    //-- Oscillators parameters
    unsigned int _A;  //-- Amplitude (degrees)
    unsigned int _O;  //-- Offset (degrees)
    unsigned int _T;  //-- Period (miliseconds)
    double _phase0;   //-- Phase (radians)
    //-- Internal variables
    int _pos;         //-- Current servo pos
    int _trim;        //-- Calibration offset
    double _phase;    //-- Current phase
    double _inc;      //-- Increment of phase
    unsigned int _TS; //-- sampling period (ms)
    long _previousMillis;
    long _currentMillis;
    //-- Oscillation mode. If true, the servo is stopped
    bool _stop;
    //-- Reverse mode
    bool _rev;
#endif
Thanks in advance for checking out my problem
Using the 1.6.0 version of the IDE, with the Oscillator files in the same folder as the sketch, changing
to
resulted in the single error message:
Sketch uses 5,172 bytes (16%) of program storage space. Maximum is 32,256 bytes.
Global variables use 266 bytes (12%) of dynamic memory, leaving 1,782 bytes for local variables. Maximum is 2,048 bytes.
Usually, that's the message people try to get.
Arduino doesn't really have doubles, but as far as I know you can use them, you just get a 32 bit float anyway.
The problem there is, somehow, with your declaration of _N. The other two errors are consequences of the declaration of _N.
Things to check: problem on the preceding line.
Some non-printing ( invisble ) character on the line. Delete the line and type it again.
Unless you are planning to travel back in time to 2010, delete the Wprogram.h stuff, it is obsolete
and maybe somehow still being selected.
Check there is nowhere else that _N is defined.
Make sure you don't have multiple, different, copies of Oscillator.h
