mimom
May 2, 2022, 3:07pm
1
I wanted to make this led display project ( Digital clock Max 7219 dot matrix Random animation & how to set the time in the RTC module with code - YouTube ) so i bought all the materials needed but it didnt work the led display is flashing in a random fashion and even turn on when the vcc and gnd aren't connected to the display.
To check the other part and the board i tried to connect the arduino and display directly using this video (Arduino Text Scrolling Display | MAX7219 Dot Matrix 4-in-1 - YouTube ) but still not working and still turn on even while gnd and vcc isn't connected to the led
Sending us around the web for information isn’t recommended.
Please follow the forum guidelines.
See also FAQ - Arduino Forum for general rules on forum behaviour and etiquette.
Hello,
Welcome to the Arduino Forum.
This guide explains how to get the best out of this forum. Please read and follow the instructions below.
Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is fru…
Show us a good schematic of your proposed circuit.
Show us a good image of your ‘actual’ wiring.
Give links to components.
In the Arduino IDE, use Ctrl T or CMD T to format your code then copy the complete sketch .
Use the </> icon from the ‘reply menu’ to attach the copied sketch.
How to troubleshooting my project
Hello mimom
Take a view here to gain the knowledge.
You thought of an amazing project, put together the electronics, wrote code, but nothing works? This guide will take you through the steps of Arduino debugging, for both hardware and software, including simulators and emulators for Arduino.
Дайте миру шанс!
@mimom
Your topic was moved to its current location as it is more suitable.
Thank you
system
Closed
October 29, 2022, 3:45pm
5
