Hello, I am trying to make less power consumption for nodemcu. I know there is a sleep mode we can use but I need to go deeper. I want to cut off the power somehow. I was thinking make with timer. I will send data to timer for setting a time. When the time comes it will send to 3v signal to mosfet and it will open the gate for power. The problem is with timer. I really don’t know now is there a timer for my purpose.
Also i tried to draw on excel what i was planning.
SlimeDont5:
Why?
Note that the ESP has a "CH_PD" pin which turns it completely off with a very small power drain. If you use the right regulators, you do not need any extra components to shut off the power. A NodeMCU may not be the best choice for this, if for no other reason that it has a USB chip drawing power even if it is not used.
Thank you for your respond. I am using a old notebook battery and there is no charge cable and other things so that is the main reason why i am trying to cut power. I am trying to get lowest possible power consumption cause I don’t know when batteries is gonna die.
If Nodemcu is not best choice for this project, I would like to get your idea. I want to control my dc motor via WiFi. This is kinda irragation project so I made android app and connected to firebase. I am sending two time variable with android app. One of them is for engine and the other is for sleeping time. I get the value for engine and its works for x(it depends on value) second. After the job finished, it gets sleeping time and makes nodemcu sleep.
Well, clearly it cannot receive commands while it is asleep, though there is a partial sleep mode in which it can. The trade-off is that it still uses significant power.
You suggest you propose to put it to sleep and use a timer to wake it again when another job is scheduled. Presumably you will be using a RTC such as a DS3231 to do this, which keeps time using its own lithium "button cell". You can most certainly do this using the CH_PD pin to shut the ESP completely down.
The most basic ESP is the ESP-01. This has eight interface pins including the 3.3 V Vcc and ground, Rx, Tx, CH_PD, reset and two GPIO. You need a 3.3 V regulator to power it from any higher voltage so you would need one which itself had negligible "standby" current.
At least the OP did provide project details so we can suggest better methods.
OP- Have you considered the power drain of the timer, or will you be using a wind-up alarm clock?
I actually did. I was probably going to use DS1302 or same type module. They have own batteries but I didn’t mention on purpose because ı wasn't sure which type timer I will use.
Also I would like to thanks @Paul__B. I am considering his suggestion. His idea already what I was thinking before.
