LIBRARIES THAT COULD NOT BE IMPORTED:
[] [18CDEj0f] 400 invalid_request: attribute "name" of response is missing and required, attribute: name, parent: response
The examples will import to sketchbook if zipped on thier own.
I tried a few variations with the libs but get a different file name error with each import even though I am using the same zip file with all the source files in a single directory.
Some of the team will be on Holiday but hopefully somebody will be about on Monday to review this.
Try this: Get the library again, make sure it is zipped when you get it. If not, zip it. DO NOT open the library! Go to web editor, go to libraries, click import, click import again, choose the ZIPPED library, and I think you click import again. It should work. It worked for me.
I just tried to upload a new custom library member.
I received the following message:
[] [A3t2aTfK] 400 invalid_request: attribute "name" of response is missing and required, attribute: name, parent: response
I was previously successful in uploading new library members last month.
Has something changed.
I restarted my browser, the plug-n, and removed and plugged in the board. Nothing seems to help.
I have a sketch which includes to cpp and .h members and that script works correctly.
When I upload it to the library tab, the error message is: 400 invalid_request: attribute "name" of response is missing and required, attribute: name, parent: response
