How to upload several files to microcontroller
Hi guys,
I am a beginner, I've never programmed before, so bare with me.
I have Arduino Uno R4 Minima and I'm trying to recreate a project, which is a One-touch turn signal module that I found on Revtor's wiki page (One-touch turn signal module (NP version) - E31Wiki).
I have all the parts and want to upload the source file to the ATTiny24.
Could you please tell me why there are 3 different files (common.h, OTTS-NP.c, OTTS-NP.hex) he provided, and which one needs to be uploaded to the microcontroller and how to do that?
I assume that a common is some sort of personal library or something like that, but I really don't know what I should do to get this code up and running.
Are there any tips anyone could give me?
Also, if anyone thinks they could take a peek at the code and help me understand it, I would really appreciate it and I'll send the code to you.
Thanks in advance!
The C file is most likely the open text, ‘source’ file that you could modify and recompile for your own needs.
The hex file is most likely the executable binary code for the target system (his target), so if yours is physically identixal, it should run on yours.
the .c and .h are the program that is compiled into the .hex file which is then downloaded to the chip.
Use the Arduino IDE to load, compile and upload the main project file (*.c or *.cpp). Set the right port and target module (ATTiny24) before compilation.
Hi DrDiettrich,
Thanks for your reply.
so do you mean, no need to worried about the hex file, only need to use the two source files (common.h, OTTS-NP.c) which are written in C+?
if so I have two question:
  1. can I copy the common file into the OTTS-NP.c file to have one file at final?
  2. if not, how to upload the 2 files using the Arduino IDE?
As I am a beginner, sorry about any simple question. This is my first project.
I can share the all the files to get a better understanding.
Hi Lastchancename,
My question is, if my device is almost the same the only difference is I would use Attiny24A instead of ATtiny 24-20PU MCU.
Do I still need to upload all three files?
And if so, how should I do it?
That's what the IDE does for you. The *.c and *.h files are for human use, the IDE compiles everything for controller use (upload)..
If your hardware is identical, you only need a ‘programmer’,
Something like avrdude within the IDE, or another device (like a UNO) which can be programmed as a n ISP programmer’ for your target device.
my device is almost the same, the only difference is I would use Attiny24A instead of ATtiny 24-20PU MCU.
and I have Uno R4 Minima for programming.
the only problem is, I don't know what is the way to upload 2 (or the three?) files.
I've seen many videos where only one file was uploaded instead of two or three.
I see, the only problem is, I don't know what is the way to upload 2 files.
Hi Gcjr,
If I understand you well, it means I don't need to use the hex file but the common.h and OTTS-NP.c for uploading the program
You only need the c and h files if you’re recompiling.(which you might need because it’s a different variant of the same controller chip).
But to keep life simple, you can try uploading the existing hex file as it’s the ‘already compiled version of the existing c and h files)
We’ve all even lucky once !
Hi @djseo.
I'll provide instructions you can follow to do this:
A. Set up UNO R4 Minima as "Arduino as ISP"
  1. Disconnect the USB cable of the UNO R4 Minima board from your computer if it is connected.
  2. Make the following connections between the pins on the programmer (the UNO R4 Minima) and the target (the ATtiny24):
    Programmer Target
    CIPO (AKA "MISO") CIPO
    VCC 5V (VCC on 3.3 V boards)
    SCK SCK
    COPI (AKA "MOSI") COPI
    10 RESET
    GND GND
    Check the pinout diagram on the documentation page for the UNO R4 Minima for the location of these pins.
  3. If you haven't already, install Arduino IDE 2.3.3.
    • Arduino IDE can be downloaded from the links listed on the Software page:
      https://www.arduino.cc/en/software
    • :exclamation: You should use a recent version of Arduino IDE as there is a bug in the "ArduinoISP" sketch included in older versions.
  4. Start Arduino IDE.
  5. Connect the UNO R4 Minima board to your computer with a USB cable.
  6. Select File > Examples > 11.ArduinoISP > ArduinoISP from the Arduino IDE menus.
    The "ArduinoISP" sketch will open in Arduino IDE.
  7. Select the port of the UNO R4 Minima board from the menu on the Arduino IDE toolbar.
  8. Select Sketch > Upload from the Arduino IDE menus.
  9. Wait for the upload to finish successfully, as indicated by a success notification at the bottom right corner of the Arduino IDE window.
B. Install Support for ATtiny24
  1. Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
    The "Preferences" dialog will open.
  2. Enter the following URL into the "Additional Boards Manager URLs" field in the "Preferences" dialog:
    https://raw.githubusercontent.com/per1234/ReleaseScripts/refs/heads/provisional-package-index/package_drazzy.com_index.json
    :exclamation: If there are already Boards Manager URLs in the field, separate them with commas.
  3. Click the "OK" button.
    The "Preferences" dialog will close.
  4. You will now see a "Downloading index: ..." notification at the bottom right corner of the IDE window. Wait for that notification to close.
  5. Select Tools > Board > Boards Manager... from the Arduino IDE menus to open the "Boards Manager" view in the left side panel.
  6. Scroll down through the list of boards platforms until you see the "ATTinyCore" entry.
  7. Click the "INSTALL" button at the bottom of the entry.
  8. Wait for the installation process to finish, as indicated by a notification at the bottom right corner of the Arduino IDE window:
    Successfully installed platform ...
C. Convert the "OTTS-NP" Program to an Arduino Sketch
  1. Click the following link to open the tutorial:
  2. Click the "One-touch turn signal module source code and binary" link under the "Source code and binary" section of the page.
  3. Wait for the download to finish.
  4. Extract the downloaded file.
  5. Rename the extracted folder from OTTSv3_module_source_code_binary_(NP_version) to OTTS-NP.
  6. Create a file named OTTS-NP.ino in the OTTS-NP folder.
    • :warning: Make sure the file is named OTTS-NP.ino exactly, not something like OTTS-NP.ino.txt.
    • The OTTS-NP.ino makes the project into a valid Arduino sketch which can be compiled and uploaded using Arduino IDE. The OTTS-NP.ino file will be empty as the actual program is in the other source files that were provided by the tutorial author.
  7. Verify that the folder now has the following structure:
    OTTS-NP/
    ├── OTTS-NP.c
    ├── OTTS-NP.hex
    ├── OTTS-NP.ino
    └── common.h
  8. Switch to the Arduino IDE window.
  9. Select File > Open from the Arduino IDE menus.
    The "Open" dialog will open.
  10. Select the OTTS-NP.ino file from the dialog.
  11. Click the "Open" button.
The "OTTS-NP" sketch will now open in a new Arduino IDE window.
D. Upload Sketch to ATtiny24
  1. Select Tools > Board > ATTinyCore > ATtiny24/44/84(a) (No bootloader) from the Arduino IDE menus.
  2. Select Tools > Chip > ATtiny24(a) from the Arduino IDE menus.
  3. Select Tools > Programmer > Arduino Leo/Micro as ISP (ATmega32U4) from the Arduino IDE menus.
  4. Adjust the configuration of the other Tools menus as is appropriate for your project.
    :warning: An incorrect configuration could result in your ATtiny24 chip being "soft bricked" by the subsequent steps in these instructions.
  5. Select Tools > Burn Bootloader from the Arduino IDE menus.
    This is done to configure the fuses on the ATtiny24 according to the board configuration in Arduino IDE.
  6. Wait for the "Burn Bootloader" operation to finish successfully, as indicated by a success notification at the bottom right corner of the Arduino IDE window.
  7. Select Sketch > Upload using Programmer from the Arduino IDE windows.
  8. Wait for the "Upload using Programmer" operation to finish successfully, as indicated by a success notification at the bottom right corner of the Arduino IDE window.
The ATtiny24 chip will now be running the "OTTS-NP" program. You can disconnect the UNO R4 Minima from the ATtiny24.
Hi Ptillisch,
thank you so much for your very detailed answer, I really appriciate your time and effort to help me to solve my problem.
I think this is the solution, but I got this error message when I performed #8 step in section A (Sketch> Upload):
TinySoftwareSerial.cpp.o (symbol from plugin): In function `TinySoftwareSerial::available()':
(.text+0x0): multiple definition of `getch'
C:\Users\Fazekas J�nos\AppData\Local\Temp\arduino\sketches\E05735BA9AD106983E457772A433046C\sketch\ArduinoISP.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
I'm going to ask you to provide the full verbose output from a compilation of the "ArduinoISP" sketch.
:exclamation: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  2. Check the box next to "Show verbose output during: ☐ compile" in the "Preferences" dialog.
  4. Attempt to upload the "ArduinoISP" sketch to the UNO R4 Minima board again, just as you did before when you encountered this error.
  5. Wait for the compilation to fail.
  6. You will see a "Compilation error: ..." notification at the bottom right corner of the Arduino IDE window. Click the "COPY ERROR MESSAGES" button on that notification.
  7. Open a forum reply here by clicking the "Reply" button.
  8. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
  9. Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
    This will paste the compilation output into the code block.
  10. Move the cursor outside of the code block markup before you add any additional text to your reply.
  11. Click the "Reply" button to post the output.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here.
Click here for attachment instructions
  1. Open any text editor program.
  2. Paste the copied output into the text editor.
  3. Save the file in .txt format.
  4. Open a forum reply here by clicking the "Reply" button.
  5. Click the "Upload" icon (Upload icon) on the post composer toolbar:
  6. Select the .txt file you saved from the "Open" dialog.
  7. Click the "Open" button.
    The dialog will close.
  8. Click the "Reply" button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
FQBN: ATTinyCore:avr:attinyx4:chip=24
Using board 'attinyx4' from platform in folder: C:\Users\Fazekas János\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2
Using core 'tiny' from platform in folder: C:\Users\Fazekas János\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2
Detecting libraries used...
C:\Users\Fazekas János\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny24 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10607 -DARDUINO_AVR_ATTINYX4 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTA -IC:\Users\Fazekas János\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\cores\tiny -IC:\Users\Fazekas János\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\variants\tinyX4_reverse C:\Users\Fazekas János\AppData\Local\Temp\arduino\sketches\E05735BA9AD106983E457772A433046C\sketch\ArduinoISP.ino.cpp -o nul
Alternatives for SPI.h: [SPI@2.0.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@2.0.0]
C:\Users\Fazekas János\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny24 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10607 -DARDUINO_AVR_ATTINYX4 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTA -IC:\Users\Fazekas János\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\cores\tiny -IC:\Users\Fazekas János\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\variants\tinyX4_reverse -IC:\Users\Fazekas János\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\libraries\SPI C:\Users\Fazekas János\AppData\Local\Temp\arduino\sketches\E05735BA9AD106983E457772A433046C\sketch\ArduinoISP.ino.cpp -o nul
C:\Users\Fazekas János\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny24 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10607 -DARDUINO_AVR_ATTINYX4 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTA -IC:\Users\Fazekas János\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\cores\tiny -IC:\Users\Fazekas János\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\variants\tinyX4_reverse -IC:\Users\Fazekas János\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\libraries\SPI C:\Users\Fazekas János\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\libraries\SPI\SPI.cpp -o nul
Generating function prototypes...
C:\Users\Fazekas János\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny24 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10607 -DARDUINO_AVR_ATTINYX4 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTA -IC:\Users\Fazekas János\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\cores\tiny -IC:\Users\Fazekas János\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\variants\tinyX4_reverse -IC:\Users\Fazekas János\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\libraries\SPI C:\Users\Fazekas János\AppData\Local\Temp\arduino\sketches\E05735BA9AD106983E457772A433046C\sketch\ArduinoISP.ino.cpp -o C:\Users\Fazekas János\AppData\Local\Temp\232872081\sketch_merged.cpp
C:\Users\Fazekas János\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\Fazekas János\AppData\Local\Temp\232872081\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\Fazekas János\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=attiny24 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10607 -DARDUINO_AVR_ATTINYX4 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTA "-IC:\\Users\\Fazekas János\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Fazekas János\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX4_reverse" "-IC:\\Users\\Fazekas János\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Fazekas János\\AppData\\Local\\Temp\\arduino\\sketches\\E05735BA9AD106983E457772A433046C\\sketch\\ArduinoISP.ino.cpp" -o "C:\\Users\\Fazekas János\\AppData\\Local\\Temp\\arduino\\sketches\\E05735BA9AD106983E457772A433046C\\sketch\\ArduinoISP.ino.cpp.o"
Compiling libraries...
Compiling library "SPI"
"C:\\Users\\Fazekas János\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=attiny24 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10607 -DARDUINO_AVR_ATTINYX4 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTA "-IC:\\Users\\Fazekas János\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Fazekas János\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX4_reverse" "-IC:\\Users\\Fazekas János\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI" "C:\\Users\\Fazekas János\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries\\SPI\\SPI.cpp" -o "C:\\Users\\Fazekas János\\AppData\\Local\\Temp\\arduino\\sketches\\E05735BA9AD106983E457772A433046C\\libraries\\SPI\\SPI.cpp.o"
Compiling core...
Using precompiled core: C:\Users\Fazekas János\AppData\Local\Temp\arduino\cores\5c3ead203549e14dcee4c140bff1cc96\core.a
Linking everything together...
"C:\\Users\\Fazekas János\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=attiny24 -o "C:\\Users\\Fazekas János\\AppData\\Local\\Temp\\arduino\\sketches\\E05735BA9AD106983E457772A433046C/ArduinoISP.ino.elf" "C:\\Users\\Fazekas János\\AppData\\Local\\Temp\\arduino\\sketches\\E05735BA9AD106983E457772A433046C\\sketch\\ArduinoISP.ino.cpp.o" "C:\\Users\\Fazekas János\\AppData\\Local\\Temp\\arduino\\sketches\\E05735BA9AD106983E457772A433046C\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\Fazekas János\\AppData\\Local\\Temp\\arduino\\sketches\\E05735BA9AD106983E457772A433046C/..\\..\\cores\\5c3ead203549e14dcee4c140bff1cc96\\core.a" "-LC:\\Users\\Fazekas János\\AppData\\Local\\Temp\\arduino\\sketches\\E05735BA9AD106983E457772A433046C" -lm
Using library SPI at version 2.0.0 in folder: C:\Users\Fazekas János\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\libraries\SPI
exit status 1
You didn't follow step A.5 correctly.
Select Tools > Board > Arduino UNO R4 Boards > Arduino UNO R4 Minima from the Arduino IDE menus and then try uploading the "ArduinoISP" sketch to the board once again.
I couldn't see this step in the original article but I performed that and then succeeded.
Then I was able to upload the sketch to the ATtiny as well.
Thank you so much again!
  1. Do I need to perform the Burn Bootloader every time i change something in the code, or only the first time using brand new ATtiny?
  2. Is that normal that the OTTS-NP.ino file is empty?
Great job on accomplishing this complex procedure!
You only need to perform a "Burn Bootloader" operation under one of the following conditions:
  • You are working with a new microcontroller. In this case, the chip's fuses will be configured according to the factory defaults, which might be different from the configuration you want.
  • You changed one of the relevant options from the menus under Arduino IDE's Tools menu. Some of these options define fuse configurations, and so will only take effect after you perform a "Burn Bootloader" operation.
But you don't need to perform a "Burn Bootloader" operation if you only changed something in the sketch code. In this case you can simply perform an "Upload Using Programmer" operation.
If you are uploading to the ATtiny24 frequently, you might like to know that you can also just click the "Upload" button on the Arduino IDE toolbar, just like you would when uploading a sketch to the UNO R4 Minima board. The "ATtiny24/44/84(a) (No bootloader)" board definition of ATTinyCore is configured so that clicking the "Upload" button performs an "Upload Using Programmer" operation. So clicking the button is functionally equivalent to selecting Sketch > Upload Using Programmer, but slightly more convenient.
Not normal, but it is appropriate in this particular case.
Every C++/C program must have a main function. In the Arduino world, this function is hidden away in the core of each Arduino boards platform. For example, you can see the main function in the "ATTinyCore" platform's core here:
Note that this main function calls a function named setup:
and another function named loop:
These functions are expected to be defined in the user's code in the sketch. This system is intended to make it easier for beginners to get started with Arduino by allowing them to avoid having to implement the code for an infinite loop that most any embedded systems program will use:
However, it is possible for us to circumvent that convenience system if we like, and instead define our own main function in the sketch program. If this is done, it overrides the main function defined by the core.
Since the "OTTS-NP" program is just a pure C program; not dependent on the Arduino build system and core, a main function is defined in that OTTS-NP.c file:
int main(void)
and this is a complete program without any need for additional code in the .ino file.
However, if you like, you are welcome to add code to OTTS-NP.ino. You could probably even copy all the code from OTTS-NP.c to OTTS-NP.ino and delete OTTS-NP.c. OTTS-NP.c is written in the C programming language, and the .c file extension causes it to be compiled as C by the Arduino sketch build system. Conversely, we use the "Arduino programming language" (essentially C++) in .ino files, and the sketch build system compiles the code in .ino files as such. However, C++ is a superset of C, so it is likely that the code in OTTS-NP.c will work just as well if it was moved to OTTS-NP.ino.
If you are going to add your own code, keep in mind that the main function defined in the OTTS-NP.c code does not call setup and loop functions, so if you try to write the sketch code as usual by putting it in functions with those names, your code won't ever be executed (unless you added setup() and loop() calls to the program's main function).
I really appriciate your help, thanks a million!
