How to Upload Without Compiling?
Every time I compile a sketch and then hit upload it compiles again and then uploads. Due to an issue with the old Arduino Nano bootloader I need to upload a program without compiling it. Is there a way I can upload a program to my nano without first compiling?
Issue: The old nano bootloader has a WDT issue. if I can upload a program to the nano before it boots up I can bring it back. If I try to connect the nano and hit upload, the time it takes to recompile is too long and it cannot be reprogrammed. I don't have the cables to burn the bootloader the the moment.
Bootlaod the Nano with a new bootloader and no more problem. It is not hard to burn a bootloader using another Arduino and the ArduinoISP sketch. You just need 6 pieces of wire, no special connector.
Try holding down the reset button until the compilation is finished.
Sounds like the old bootloader isn't clearing the wdt flag. Where is the old bootloader located and can I edit it to fix it? Surprised this hasn't been fixed...
It has.
It resides in the Arduino's flash memory.
You don't edit any files. In post #2 there is a link that explains the process.
