How to use 2.4inch TFT LCD ILI9341 along with BMP180 pressure sensor
hi guys, im new to arduino forum, recently ive been working on a project and im stuck at a point where i cant use both the modules together -.-"
if i want to use the TFT it works fine with my code, but when i add the code for BMP180 pressure sensor the TFT gives a blank white screen, im fairly certain that the problem is with my coding, since its my first attempt at using these 2 modules, and my first attempt at using something with SCL and SDA, i dont know what i should do now, i spent hrs searching net but im still not able to fine a solution.
im attaching my code with this post , can someone verify it and tell me what is wrong in it?
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_TFTLCD.h> // Hardware-specific library
#include <TouchScreen.h>
#include <Banggood9341_Hack.h>
#include <SFE_BMP180.h>
#include <Wire.h>
SFE_BMP180 pressure;
#define ALTITUDE 1655.0 // Altitude of SparkFun's HQ in Boulder, CO. in meters
#if defined(__SAM3X8E__)
    #undef __FlashStringHelper::F(string_literal)
    #define F(string_literal) string_literal
#endif
// When using the BREAKOUT BOARD only, use these 8 data lines to the LCD:
// For the Arduino Uno, Duemilanove, Diecimila, etc.:
//   D0 connects to digital pin 8  (Notice these are
//   D1 connects to digital pin 9   NOT in order!)
//   D2 connects to digital pin 2
//   D3 connects to digital pin 3
//   D4 connects to digital pin 4
//   D5 connects to digital pin 5
//   D6 connects to digital pin 6
//   D7 connects to digital pin 7
// For the Arduino Mega, use digital pins 22 through 29
// (on the 2-row header at the end of the board).
//   D0 connects to digital pin 22
//   D1 connects to digital pin 23
//   D2 connects to digital pin 24
//   D3 connects to digital pin 25
//   D4 connects to digital pin 26
//   D5 connects to digital pin 27
//   D6 connects to digital pin 28
//   D7 connects to digital pin 29
#define YP A1  // must be an analog pin, use "An" notation!
#define XM A2  // must be an analog pin, use "An" notation!
#define YM 7   // can be a digital pin
#define XP 6   // can be a digital pin
#define TS_MINX 150
#define TS_MINY 120
#define TS_MAXX 920
#define TS_MAXY 940
                // For better pressure precision, we need to know the resistance
               // between X+ and X- Use any multimeter to read it
               // For the one we're using, its 300 ohms across the X plate
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
// optional
#define LCD_RESET 12
// Assign human-readable names to some common 16-bit color values:
#define  BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
int currentcolor = WHITE;
int pressure_value,i=0;
void setup(void) {
 Serial.println(F("Touch screen!"));
 tft.reset();
 uint16_t identifier = 0x9341;
 if(identifier == 0x9341) {
    Serial.println(F("Found ILI9341 LCD driver"));
  tft.begin(identifier);
  Lcd_Init();
  tft.fillScreen(BLACK);
  tft.setTextSize (3); // We define text size.
  tft.setTextColor (BLACK); // define the text color
  tft.setRotation (90); // We set the screen Vertical or Horizontal
  tft.fillRect(10, 10, 100, 100, WHITE);
  tft.fillRect(130, 10, 100, 100, WHITE);
  tft.fillRect(10, 120, 220, 90, WHITE);
  tft.fillRect(10, 220, 220, 90, WHITE);
  pinMode(13, OUTPUT);
#define MINPRESSURE 5// minimum should be > 0
#define MAXPRESSURE 1000
int getpressure()
{    if (pressure.begin())
    Serial.println("BMP180 init success");
    Serial.println("BMP180 init fail\n\n");
  char status;
  double T,P,p0,a;
  pressure.startTemperature();
  status = pressure.getTemperature(T);
    if (status != 0)
    { status = pressure.getPressure(P,T);
        if (status != 0)
          // Print out the measurement:
          Serial.print("absolute pressure: ");
          Serial.print(P,2);
          pressure_value=P;
 return pressure_value;
{ digitalWrite(13, HIGH);
  tft.setCursor (15, 50);   // Place the cursor
  tft.println ( "START" ); // write our text on the LCD
  tft.setCursor (140, 50);   // Place the cursor
  tft.println ( "PAUSE" ); // write our text on the LCD
  tft.setCursor (90, 155);   // Place the cursor
  tft.println ( "STOP" ); // write our text on the LCD
  tft.setCursor (50, 250);   // Place the cursor
  tft.println ( "SETTINGS" ); // write our text on the LCD
  TSPoint p = ts.getPoint();
  int16_t tempX = p.x;
  p.x = 1023-p.y;
  p.y = 1023-tempX;
  digitalWrite(13, LOW);
  pinMode(XM, OUTPUT);
  pinMode(YP, OUTPUT);
  // scale from 0->1023 to tft.width
  p.x = map(p.x, TS_MINX, TS_MAXX, tft.width(), 0);
  p.y = map(p.y, TS_MINY, TS_MAXY, tft.height(), 0);
  Serial.print("("); Serial.print(p.x);
  Serial.print(", "); Serial.print(p.y);
  Serial.println(")");
     if (p.y < 110 && p.x < 110) {
           tft.fillRect(10, 10, 100, 100, GREEN);
     if (p.y < 110 && p.x > 120 && p.x <200) {
           tft.fillRect(130, 10, 100, 100, YELLOW);
     if (p.y > 120 &&  p.y <220) {
           tft.fillRect(10, 120, 220, 90, RED);
     if (p.y > 220 &&  p.y <310) {
           tft.fillRect(10, 220, 220, 90, BLUE);
  Serial.print("  "); Serial.print(pressure_value);
  Serial.println("\n");
Hi Nightmare,
In your 'loop' where is the call to "getpressure" - it needs to be in the loop !
Good Luck
