How to use 2 Acelerometers MPU6050 in 1 ESP 32
Hello, I would like to be able to use 2 accelerometers with my esp 32, but when I use both at the same time, both appear equal values in their measurements. I would like to know how I can measure each one separately on the same esp 32.
follow the code below
// Basic demo for accelerometer readings from Adafruit MPU6050
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
//Adafruit_MPU6050 mpu;
Adafruit_MPU6050 MPU1;
Adafruit_MPU6050 MPU2;
void setup(void) {
  while (!Serial)
    delay(10); // will pause Zero, Leonardo, etc until serial console opens
  Serial.println("Adafruit MPU6050 test!");
  // Try to initialize!
  if (!MPU1.begin() || !MPU2.begin(0x69)) {
    Serial.println("Failed to find one or both MPU6050 chip(s)");
    while (1) {
      delay(10);
  Serial.println("Both MPU6050s found!");
  MPU1.setAccelerometerRange(MPU6050_RANGE_8_G);
  Serial.print("Accelerometer range set to: ");
  switch (MPU1.getAccelerometerRange()) {
  case MPU6050_RANGE_2_G:
    Serial.println("+-2G");
  case MPU6050_RANGE_4_G:
    Serial.println("+-4G");
  case MPU6050_RANGE_8_G:
    Serial.println("+-8G");
  case MPU6050_RANGE_16_G:
    Serial.println("+-16G");
  MPU1.setGyroRange(MPU6050_RANGE_500_DEG);
  Serial.print("Gyro range set to: ");
  switch (MPU1.getGyroRange()) {
  case MPU6050_RANGE_250_DEG:
    Serial.println("+- 250 deg/s");
  case MPU6050_RANGE_500_DEG:
    Serial.println("+- 500 deg/s");
  case MPU6050_RANGE_1000_DEG:
    Serial.println("+- 1000 deg/s");
  case MPU6050_RANGE_2000_DEG:
    Serial.println("+- 2000 deg/s");
  MPU1.setFilterBandwidth(MPU6050_BAND_21_HZ);
  Serial.print("Filter bandwidth set to: ");
  switch (MPU1.getFilterBandwidth()) {
  case MPU6050_BAND_260_HZ:
    Serial.println("260 Hz");
  case MPU6050_BAND_184_HZ:
    Serial.println("184 Hz");
  case MPU6050_BAND_94_HZ:
    Serial.println("94 Hz");
  case MPU6050_BAND_44_HZ:
    Serial.println("44 Hz");
  case MPU6050_BAND_21_HZ:
    Serial.println("21 Hz");
  case MPU6050_BAND_10_HZ:
    Serial.println("10 Hz");
  case MPU6050_BAND_5_HZ:
    Serial.println("5 Hz");
  MPU2.setAccelerometerRange(MPU6050_RANGE_8_G);
  switch (MPU2.getAccelerometerRange()) {
  MPU2.setGyroRange(MPU6050_RANGE_500_DEG);
  switch (MPU2.getGyroRange()) {
  MPU2.setFilterBandwidth(MPU6050_BAND_21_HZ);
  switch (MPU2.getFilterBandwidth()) {
  Serial.println("");
  delay(100);
  GetMPU1();
  GetMPU2();
  Serial.println("-----------");
void GetMPU1(){
  /* Get new sensor events with the readings */
  sensors_event_t a, g, temp;
  MPU1.getEvent(&a, &g, &temp);
  /* Print out the values */
  Serial.print("Acceleration X: ");
  Serial.print(a.acceleration.x);
  Serial.print(", Y: ");
  Serial.print(a.acceleration.y);
  Serial.print(", Z: ");
  Serial.print(a.acceleration.z);
  Serial.println(" m/s^2");
  Serial.print("Rotation X: ");
  Serial.print(g.gyro.x);
  Serial.print(g.gyro.y);
  Serial.print(g.gyro.z);
  Serial.println(" rad/s");
  Serial.print("Temperature: ");
  Serial.print(temp.temperature);
  Serial.println(" degC");
void GetMPU2(){
  MPU2.getEvent(&a, &g, &temp);
When the I2C scanner is used what is reported?
How do I use the I2C scanner?
The words in an internet search "arduino i2c scanner" might provide answers.
A scan of the I2c bus is unuseful, both modules have the same and cannot be changed by code.
The default address is 0X68 and both have the same address.
The only option is by hardware. The ADO pin of the MPU6050 module has an internal resistor connected to GND that sets its address to 0x68, but if we set it to HIGH it changes its I2C address to 0x69.
You will have to connect the ADO pins of your modules to two digital pins of the esp32 to put one of them HIGH to change its address and be able to read from the other that its ADO will be LOW.
Why do you need two IMUs?
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
