How to use 2 SPI devices
Hello friends,
I'm trying to join 2 programs, ,but both are using the SPI in the arduino, and so we have a problem :(
This are the projects: LCD controlled over Ethernet:http://everettsprojects.com/2011/05/19/arduino-project-html-to-lcd/ LED Matrix: http://www.instructables.com/id/Make-a-24X6-LED-matrix/?ALLSTEPS
I wish to make a led matrix controlled over the ethernet shield.
The problem is that the matrix uses the SPI and the ethernet too..
Someone has an idea or a answer for this problem??
Thanks a lot
No, we don't. You might, but the Arduino won't.
What is the problem?
My problem is: how to use 2 SPI devices?
Each needs to have it's own chip/slave select pin. Set one HIGH and the other LOW to talk to one device. Swap which is HIGH and which is LOW to talk to the other device.
is the SS pin that i have to set high and low??
Yes. SS = slave select.
