How to use a function in a sketch
I have some problems for writting my code, i don't know how to use those functions in my sketch:
void BPLib::gameJoyPress(byte BP_ST_BTN, byte BP_ND_BTN){
Serial1.write((byte)0xFD); //Start HID Report
Serial1.write((byte)0x6); //Length byte
Serial1.write((byte)BP_ST_BTN); //First Button byte
Serial1.write((byte)BP_ND_BTN); //Second Button byte
for(byte i = 0;i<4;i++){ //Send four zero bytes
Serial1.write((byte)0x00);
void BPLib::gameJoyMove(signed int BP_X1,signed int BP_Y1,signed int BP_X2,signed int BP_Y2){
Serial1.write((byte)BP_GAMEJOY_ST_NOBTN); //First Button byte
Serial1.write((byte)BP_GAMEJOY_ND_NOBTN); //Second Button byte
Serial1.write(BP_X1 & 0xFF);	//First X coordinate
Serial1.write(BP_Y1 & 0xFF);	//First Y coordinate
Serial1.write(BP_X2 & 0xFF);	//Second X coordinate
Serial1.write(BP_Y2 & 0xFF);	//Second Y coordinate
void BPLib::gameJoyReleaseAll(){
gameJoyPress(BP_GAMEJOY_ST_NOBTN, BP_GAMEJOY_ND_NOBTN);
These are the codes i should use in the first function:
//GAMEPAD/JOYSTICK BUTTON CODES
//ST == First button combination (BTN0 to BTN7)
#define BP_GAMEJOY_ST_BTN0	(1<<0)
#define BP_GAMEJOY_ST_BTN1	(1<<1)
#define BP_GAMEJOY_ST_BTN2	(1<<2)
#define BP_GAMEJOY_ST_BTN3	(1<<3)
#define BP_GAMEJOY_ST_BTN4	(1<<4)
#define BP_GAMEJOY_ST_BTN5	(1<<5)
#define BP_GAMEJOY_ST_BTN6	(1<<6)
#define BP_GAMEJOY_ST_BTN7	(1<<7)
#define BP_GAMEJOY_ST_NOBTN	0x00
//ND = Second button combination (BTN0 to BTN7)
#define BP_GAMEJOY_ND_BTN0	(1<<0)
#define BP_GAMEJOY_ND_BTN1	(1<<1)
#define BP_GAMEJOY_ND_BTN2	(1<<2)
#define BP_GAMEJOY_ND_BTN3	(1<<3)
#define BP_GAMEJOY_ND_BTN4	(1<<4)
#define BP_GAMEJOY_ND_BTN5	(1<<5)
#define BP_GAMEJOY_ND_BTN6	(1<<6)
#define BP_GAMEJOY_ND_BTN7	(1<<7)
#define BP_GAMEJOY_ND_NOBTN	0x00
Here's a part of my sketch (with the first function):
 if (button1 == LOW){
    BPMod.gameJoyPress(BP_GAMEJOY_ST_BTN0,BP_GAMEJOY_ND_NOBTN);
    // slight delay to avoid flooding RN42.
    delay(50);
    // "lift" the key
   BPMod.gameJoyReleaseAll();
Do you think it's right way to use this function?
Thank you!!!
Please post the whole code, the snippets are not enough, sorry....
metaphor: If you bring only 4 wheels and steer to a garage it is quite difficult for the mechanic to see what is wrong ?
Ok, here is the whole code:
#include "Arduino.h"
#include "BPLib.h"
BPLib::BPLib(){
pinMode(7,INPUT);
digitalWrite(7,LOW);
byte BPLib::begin(char BP_Mode[], char BP_Type[])
Serial1.begin(115200);
Serial1.print(BP_MODE_COMMAND);
  if (get(BP_STAT_CMD, (byte)5)!=1) {
    return (byte)0;
  }//if
  Serial1.print(BP_Mode);
  if (get(BP_STAT_ACK, (byte)5)!=1) {
    return (byte)0;
  }//if
  if(strcmp(BP_Type,BP_SPP_SPP)>0){
  Serial1.print(BP_Type);
    return (byte)0;
  }//if
  Serial1.print(BP_REBOOT);
  if (get(BP_STAT_REBOOT, (byte)9)!=1) {
    return (byte)0;
  }//if
  delay(1000); //Delay (Bluetooth boot-up)
return (byte)1;
byte BPLib::sendCmd(char BP_CMD[])
    return (byte)0;
  }//if
  Serial1.print(BP_CMD);
    return (byte)0;
  }//if
  Serial1.print(BP_MODE_EXITCOMMAND);
  if (get(BP_STAT_END, (byte)5)!=1) {
    return (byte)0;
  }//if
  return (byte)1;
byte BPLib::readRaw(){
return Serial1.read();
int BPLib::available(){
return Serial1.available();
byte BPLib::get(char BP_STAT[],byte strlen)
char buffer[strlen + 1];
  while (Serial1.available() <= (strlen-1)) {};
    int count = 0;
    while (Serial1.available() > 0) {
      buffer[count]=(char)Serial1.read();
      count++;
    }//while
  buffer[strlen]=0;
    //Serial.print(buffer);//DEBUG
    if (strcmp(buffer,BP_STAT)==0) {
      return (byte)1;
    }//if
    else {
      return (byte)0;
    }//else
}//get
byte BPLib::changeName(char BP_NAME[]){
    return (byte)0;
  }//if
  Serial1.print(BP_CHANGE_NAME);
  Serial1.print(BP_NAME);
  Serial1.print(F("\r\n"));
    return (byte)0;
  }//if
    return (byte)0;
  }//if
  return (byte)1;
void BPLib::sendByte(byte rawData){
Serial1.print(rawData);
void BPLib::sendChar(char rawData){
void BPLib::sendInt(int rawData){
void BPLib::sendFloat(float rawData){
void BPLib::sendLong(long rawData){
void BPLib::sendString(char rawData[]){
byte BPLib::connected(){
return digitalRead(7);
#ifndef BPLib_h
#define BPLib_h
//Bluetooth Modes
#define BP_MODE_COMMAND    	"$$"
#define BP_MODE_EXITCOMMAND  	"---\r\n"
#define BP_MODE_SPP  			"S~,0\r\n"
#define BP_MODE_HID  			"S~,6\r\n"
#define BP_MODE_AUTOCONNECT  	"SM,6\r\n"
#define BP_MODE_MANUCONNECT  	"SM,4\r\n"
#define BP_MODE_STATUS			"SO,/#\r\n"
//Bluetooth status messages
#define BP_STAT_CMD  			"CMD\r\n"
#define BP_STAT_END  			"END\r\n"
#define BP_STAT_ACK  			"AOK\r\n"
#define BP_STAT_REBOOT  		"Reboot!\r\n"
//Bluetooth GET commands
#define BP_GET_HID  			"GH\n"
//Bluetooth system commands
#define BP_REBOOT  				"R,1\r\n"
#define BP_RECONNECT  			"C\r\n"
#define BP_CHANGE_NAME			"SN,"
//Bluetooth protocol types
#define BP_SPP_SPP				"AW\r\n"
#define BP_HID_KEYBOARD  		"SH,0200\r\n"
#define BP_HID_MOUSE  			"SH,0220\r\n"
#define BP_HID_GAMEPAD  		"SH,0210\r\n"
#define BP_HID_JOYSTICK  		"SH,0240\r\n"
#define BP_HID_COMBO  			"SH,0230\r\n"
// KEYBOARD Scan Codes
#define	BP_KEY_ENTER		0x28	//Enter
#define	BP_KEY_LEFT_ARROW	0x50	//Left arrow
#define	BP_KEY_DOWN_ARROW	0x51	//Down arrow
#define	BP_KEY_UP_ARROW		0x52	//Up arrow
#define	BP_KEY_ESCAPE		0x29	//Escape
#define	BP_KEY_CAPSLOCK		0x39	//CapsLock
#define	BP_KEY_SCROLLLOCK	0x47	//ScrollLock
#define	BP_KEY_BREAK_PAUSE	0x48	//Break-pause
#define	BP_KEY_NUMLOCK		0x53	//NumLock
#define	BP_KEY_TOGGLE_IPHONE_VIRTUAL_KEYBOARD	0x65	//Toggle iPhone Virtual Keyboard
#define	BP_KEY_LEFT_CONTROL	0xE0	//Left Control
#define	BP_KEY_LEFT_SHIFT	0xE1	//Left Shift
#define	BP_KEY_LEFT_ALT		0xE2	//Left Alt
#define	BP_KEY_LEFT_GUI		0xE3	//Left GUI
#define	BP_KEY_RIGHT_CONTROL	0xE4	//Right Control
#define	BP_KEY_RIGHT_SHIFT	0xE5	//Right Shift
#define	BP_KEY_RIGHT_ALT	0xE6	//Right Alt
#define	BP_KEY_RIGHT_GUI	0xE7	//Right GUI
#define	BP_KEY_F1	0x3A	//F1
#define	BP_KEY_F2	0x3B	//F2
#define	BP_KEY_F3	0x3C	//F3
#define	BP_KEY_F4	0x3D	//F4
#define	BP_KEY_F5	0x3E	//F5
#define	BP_KEY_F6	0x3F	//F6
#define	BP_KEY_F7	0x40	//F7
#define	BP_KEY_F8	0x41	//F8
#define	BP_KEY_F9	0x42	//F9
#define	BP_KEY_F10	0x43	//F10
#define	BP_KEY_F11	0x44	//F11
#define	BP_KEY_F12	0x45	//F12
//KEYBOARD MODEFIER CODES
#define BP_MOD_RIGHT_GUI	(1<<7)
#define BP_MOD_RIGHT_ALT	(1<<6)
#define BP_MOD_RIGHT_SHIFT	(1<<5)
#define BP_MOD_RIGHT_CTRL	(1<<4)
#define BP_MOD_LEFT_GUI		(1<<3)
#define BP_MOD_LEFT_ALT		(1<<2)
#define BP_MOD_LEFT_SHIFT	(1<<1)
#define BP_MOD_LEFT_CTRL	(1<<0)
#define BP_MOD_NOMOD		0x00
//Mouse Codes
#define BP_MOUSE_BTN_LEFT	(1<<0)
#define BP_MOUSE_BTN_RIGHT	(1<<1)
#define BP_MOUSE_BTN_MIDDLE	(1<<2)
class BPLib
public:
BPLib();
byte begin(char BP_Mode[], char BP_Type[]);
byte sendCmd(char BP_CMD[]);
void sendByte(byte rawData);
void sendChar(char rawData);
void sendInt(int rawData);
void sendFloat(float rawData);
void sendLong(long rawData);
void sendString(char rawData[]);
byte readRaw();
int available();
void keyboardPrint(char BP_MSG[]);
void keyboardPress(byte BP_KEY,byte BP_MOD);
void keyboardReleaseAll();
void mouseClick(byte BP_BUTTON);
void mouseMove(signed int BP_X,signed int BP_Y);
void mouseWheel(signed int BP_WHEEL);
void mousePress(byte BP_BUTTON);
void mouseReleaseAll();
void gameJoyPress(byte BP_ST_BTN, byte BP_ND_BTN);
void gameJoyMove(signed int BP_X1,signed int BP_Y1,signed int BP_X2,signed int BP_Y2);
void gameJoyReleaseAll();
byte connected();
byte changeName(char BP_NAME[]);
private:
byte get(char BP_STAT[], byte strlen);
#endif
And this is my sketch:
#include <BPLib.h>
const int buttonPin1 = 2;    // the number of the pushbutton pin
const int buttonPin2 = 3;
const int buttonPin3 = 4;
const int buttonPin4 = 5;
BPLib BPMod;
void setup(){
  pinMode(buttonPin1, INPUT);
  digitalWrite(buttonPin1, HIGH);
  pinMode(buttonPin2, INPUT);
  digitalWrite(buttonPin2, HIGH);
  pinMode(buttonPin3, INPUT);
  digitalWrite(buttonPin3, HIGH);
  pinMode(buttonPin4, INPUT);
  digitalWrite(buttonPin4, HIGH);
  BPMod.begin(BP_MODE_HID,BP_HID_GAMEPAD);
void loop(){
  // Check for button press
  int button1 = digitalRead(buttonPin1);
  int button2 = digitalRead(buttonPin2);
  int button3 = digitalRead(buttonPin3);
  int button4 = digitalRead(buttonPin4);
  // Check Button Press on Joystick
    BPMod.gameJoyPress(BP_GAMEJOY_ND_NOBTN,BP_GAMEJOY_ND_BTN6);
    delay(50);
    // "lift" the key
 if (button2 == LOW){
   BPMod.gameJoyPress(BP_GAMEJOY_ND_NOBTN,BP_GAMEJOY_ND_BTN7);
    delay(50);
 if (button3 == LOW){
   BPMod.gameJoyPress(BP_GAMEJOY_ST_BTN6,BP_GAMEJOY_ST_NOBTN);
    delay(50);
    // "lift" the key
 if (button4 == LOW){
    BPMod.gameJoyPress(BP_GAMEJOY_ST_BTN7,BP_GAMEJOY_ST_NOBTN);
    delay(50);
    // "lift" the key
Thank you for your help.
Hi gorafi, could you find how to use gameJoyPress and gameJoyMove functions? I'm facing the same problem
