Hi guys, i have a resistive touchscreen of a cellphone (cect i9). i disassembled the cellphone and i've taken the touchscreen.
It has a plate with 4 wires, so i linked the 1st and the 3rd (i know that in resistive touchscreen pins are x+;y+;x-;y-) and i measured with my tester the resistance, and its value changes between 0.737 mA and 0.743 mA.
Now, how to interface it with arduino?
PS. I linked only y axis, do you know another way to link that tiny wires that is not to solder them with tin? xD
dlion:
So you put your meter into resistance measurement, and it gave you values in milliamps? Milliamps are current, not resistance.
Resistive touchscreens are pretty complicated. You may want to use a touchscreen controller, that you interface to the Arduino (instead of the touchscreen itself). This the first one I found searching google for "resistive touchscreen controller."
dlion:
I'm not exactly sure what you're measuring but it shouldn't be amps.
If it's resistance you were measuring, and you want 100 steps across the screen.... you have to measure with a resolution of 0.00000006 ohms. Not going to happen.
