How to use an accelerometer to control the motor fan in Arduino UNO?
Hey! I am trying to figure out how to use an accelerometer to control the motor fan. Currently I have these two parts work separately on one Arduino, but my project is that when the reading of the accelerometer reaches a certain number, the motor fan will automatically stop working. I have the following code:
#include <Wire.h>
#include <ADXL345.h>
ADXL345 adxl; //variable adxl is an instance of the ADXL345 library
int buttonPin = 2; // button pin -- Digital 2
int relayPin = 3; // relay pin -- Digital 3
int relayState = HIGH;
int buttonState;
int lastButtonState = LOW;
long lastDebounceTime = 0;
long debounceDelay = 50;
void setup(){
  pinMode(buttonPin, INPUT);
  pinMode(relayPin, OUTPUT);
  digitalWrite(relayPin, relayState);
  adxl.powerOn();
  //set activity/ inactivity thresholds (0-255)
  adxl.setActivityThreshold(75); //62.5mg per increment
  adxl.setInactivityThreshold(75); //62.5mg per increment
  adxl.setTimeInactivity(10); // how many seconds of no activity is inactive?
  //look of activity movement on this axes - 1 == on; 0 == off
  adxl.setActivityX(1);
  adxl.setActivityY(1);
  adxl.setActivityZ(1);
  //look of inactivity movement on this axes - 1 == on; 0 == off
  adxl.setInactivityX(1);
  adxl.setInactivityY(1);
  adxl.setInactivityZ(1);
  //look of tap movement on this axes - 1 == on; 0 == off
  adxl.setTapDetectionOnX(0);
  adxl.setTapDetectionOnY(0);
  adxl.setTapDetectionOnZ(1);
  //set values for what is a tap, and what is a double tap (0-255)
  adxl.setTapThreshold(50); //62.5mg per increment
  adxl.setTapDuration(15); //625us per increment
  adxl.setDoubleTapLatency(80); //1.25ms per increment
  adxl.setDoubleTapWindow(200); //1.25ms per increment
  //set values for what is considered freefall (0-255)
  adxl.setFreeFallThreshold(7); //(5 - 9) recommended - 62.5mg per increment
  adxl.setFreeFallDuration(45); //(20 - 70) recommended - 5ms per increment
  //setting all interrupts to take place on int pin 1
  //I had issues with int pin 2, was unable to reset it
  adxl.setInterruptMapping( ADXL345_INT_SINGLE_TAP_BIT,   ADXL345_INT1_PIN );
  adxl.setInterruptMapping( ADXL345_INT_DOUBLE_TAP_BIT,   ADXL345_INT1_PIN );
  adxl.setInterruptMapping( ADXL345_INT_FREE_FALL_BIT,    ADXL345_INT1_PIN );
  adxl.setInterruptMapping( ADXL345_INT_ACTIVITY_BIT,     ADXL345_INT1_PIN );
  adxl.setInterruptMapping( ADXL345_INT_INACTIVITY_BIT,   ADXL345_INT1_PIN );
  //register interrupt actions - 1 == on; 0 == off
  adxl.setInterrupt( ADXL345_INT_SINGLE_TAP_BIT, 1);
  adxl.setInterrupt( ADXL345_INT_DOUBLE_TAP_BIT, 1);
  adxl.setInterrupt( ADXL345_INT_FREE_FALL_BIT,  1);
  adxl.setInterrupt( ADXL345_INT_ACTIVITY_BIT,   1);
  adxl.setInterrupt( ADXL345_INT_INACTIVITY_BIT, 1);
void loop(){
  // read the state of the switch into a local variable:
  int reading = digitalRead(buttonPin);
  // check to see if you just pressed the button
  // (i.e. the input went from LOW to HIGH), and you've waited
  // long enough since the last press to ignore any noise:
  // If the switch changed, due to noise or pressing:
  if (reading != lastButtonState) {
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay) {
    // whatever the reading is at, it's been there for longer
    // than the debounce delay, so take it as the actual current state:
    // if the button state has changed:
    if (reading != buttonState) {
      buttonState = reading;
      // only toggle the Relay if the new button state is HIGH
      if (buttonState == HIGH) {
        relayState = !relayState;
  // save the reading. Next time through the loop,
  // it'll be the lastButtonState:
  lastButtonState = reading;
  // set the relay:
  // Acceleromoeter
  //Boring accelerometer stuff
  int x,y,z;
  adxl.readXYZ(&x, &y, &z); //read the accelerometer values and store them in variables  x,y,z
  // Output x,y,z values
  Serial.print("values of X , Y , Z: ");
  Serial.print(x);
  Serial.print(" , ");
  Serial.print(y);
  Serial.println(z);
  double xyz[3];
  double ax,ay,az;
  adxl.getAcceleration(xyz);
  ax = xyz[0];
  ay = xyz[1];
  az = xyz[2];
  Serial.print("X=");
  Serial.print(ax);
  Serial.println(" g");
  Serial.print("Y=");
  Serial.print(ay);
  Serial.print("Z=");
  Serial.println(az);
  Serial.println("**********************");
How would I modify this code to make it do what I want it to do? Thanks!
Do some research?
How to use this forum
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
szxhsyzzy:
Start by telling us what the code does now.
Then tell us what you think might be an appropriate way to get it to do what you want - describe this in plain language, no code.
...R
This looks silly. It looks like you are comparing apples and elephants.
Wouldn't a statement like
   if(currState != prevState)
make more sense?
How many variables do you need to keep track of the current reading and the previous reading? Three is the WRONG answer!
Really? I'd have never figured that out. Thanks for stating the obvious.
What motor fan? Would that be what the relay is controlling? If so, what would the switch be doing?
Which reading of the accelerometer? You are reading 6 values from it now, although you have set up to read s s*tload more.
