Hello, I have defined and structure in the main skectch and I can use it, however I would like to have it in an external file to be imported, I am an new on it and I can not get it.
I MOVE the struct to another file named estructura.h, I put it inside libraries folder in his own folder with the same name (estructura) and I import like this in the main sketch: #include <estructura.h>
... however I get errors... with types and similar when I just copy (obviusly deleting in the main skecth).
More info: I am getting errors about boolean..... (As I told you, it works perfect from the main sketch)
content of estructura.h
enum btipo {
men,
luz,
per,
gen,
esc,
struct TBoton
{ char nombrebt[13]; de fin
// char etiqueta[13];
boolean estado;
btipo tipoboton;
boolean regulado;
int valorreg;
In file included from pruestructura.ino:2:0:
C:\Users\Pascual\Documents\Arduino\libraries\estructura/estructura.h:13:3: error: 'boolean' does not name a type
boolean estado; //estado del boton
C:\Users\Pascual\Documents\Arduino\libraries\estructura/estructura.h:15:3: error: 'boolean' does not name a type
boolean regulado; //si es o no boton regulable
pruestructura:16: error: too many initializers for 'TBoton'
pruestructura:16: error: cannot convert 'bool' to 'btipo' in initialization
pruestructura:17: error: too many initializers for 'TBoton'........
struct TBoton
{ char nombrebt[13]; de fin // <----- de fin ???
boolean estado;
btipo tipoboton;
boolean regulado;
int valorreg;
pabusa:
Eiii, thank you very much, it solves the problem. But
Could you explain why is it necessary???
Because "boolean" is not a native c/c++ type. It is defined in Arduino.h. If you don't want to include Arduino.h, then simply use "bool", which is a native c/c++ type instead of "boolean".
RayLivingston:
Regards,
Ray L.
Ummm, ok, it is really curious, so to use the native type ... (boolean) I need to import... it is like "think the opposite"
pabusa:
Thank you!!
No, you said that exactly backwards. boolean is NOT native, bool is native. You have to DEFINE any type before you can declare a variable of that type. bool is defined in the c language, so you can always use it. boolean is defined in Arduino.h, so you can use it ONLY if you include Arduino.h.
