How to use an "NTC-like" Thermal sensor
I bought an thermal sensor for a shool projekt but i have no idea how it works and i cant find anythin about it.
I you speek german look here: https://www.voelkner.de/products/938169/Iduino-Temperatursensor-Modul-ST1147-55-bis-125C.html
It just wont work like in the Tutorial from Funduino. I think its because its a different type of sensor, but i realy have no idea. Pls help!
Google "iduino temperature sensor st1477" has this as the first lisitng. Gives NTC type and code.
http://www.produktinfo.conrad.com/datenblaetter/1400000-1499999/001485330-da-01-en-IDUINO_ST1147_ANALOG_TEMP_SENSOR_MODUL.pdf
Thx so much. I did google the same thing but didnt find anything. Maybe because im from germany.
Is the following one your NTC sensor? (Collected from the Site you referred.)
Figure-1: Pictorial view
1. The R1-S network should be the following (please check):
Figure-2: S-R1 network
2. The response of the sensor module (Signal Vs Temp) is not found; so, we have to calibrate it against known two points before we use it.
3. Calibration Procedure
(a) Apply +5V between Pin-1 and Pin-3; Pin-3 is the GND potential.
(b) Connect DVM between Pin-2 and Pin-3.
(c) Record room temperature in 0C with a thermometer; record DVM reading in Volt. This is your one known point A(VDT1, T1).
(d) Change room temperature by controlling the A/C. Record room temperature in 0C with a thermometer; record DVM reading in Volt. This is your second known point B(VDT2, T2).
(e) The 3rd unknown point is C(VDT, T).
([f) Find equation for T in terms of VDT. T = k*VDT + c; where, k and c are known constatnts.
(g) If using Arduino UNO, set the VREF for the ADC at DEFAULT (5V).
(h) By simple algebraic manipulation, we will find – T = k*(5/1024)*analogRead(A3) + c.
(i) Make the following declaration/definition.
float roomTemp;
roomTemp = (float)k*(5/1024)analogRead(A3) + c;   //A3 is the ADC's channel-3.
DerAlteMalte:
In my experience, if you change the Google language to English, first, and then do the search. Then later change back to German, you may discover much information.
Paul
GolamMostafa:
The normal approximations are not that accurate for an NTC but a linear approximation is useless for a range greater than 1-2 °C. These things are totally non-linear in temperature response!
Any suggestion on how to bring reasonable linearity in the response of the NTC using hardware/software. After linearity correction, do we still need to apply the two-point calibration scheme on the NTC in order to read the unknown temperature?
Use the Steinhart & Hart equation, beta function or even a lookup table for your NTC (a list of resistances per temperature, if you have 1°C steps a linear interpolation over that one step is still quite OK).
Remember to use a precision resistor for pull-up (no more than 1% tolerance, preferably very low temperature coefficient) as otherwise that's just another major error.
