Hi, all,.
I'm learning about App Inventor. I've googled references and tutorials, but I can't understand it. maybe in this forum I can learn better... in my code the numbers can be read on the label in the application, but the background color in the "call mode_setup" block does not change.
how to communicate between arduino and app inventor.
Thank you
I don't use AppInv, but I expect:
You have now 3 conditions, even if one of them is setting background to green, 2 of them are always setting background to gray. So result is always gray.
Try to set only one condition in mode_setup, and check if it works for that number.
Common logic would be
if
then
elseif
then
elseif
then
