How to use array here need help thanks
Hi all.
the TFT_eSPI.h's pushImage class works well in the sketch.
how to use array for the jpeg[i] please?
missed the pictures, let me know if need.
Thanks
Adam
#include <TFT_eSPI.h>
#include <SPI.h>
#include "jpeg1.h"
#include "jpeg2.h"
#include "jpeg3.h"
#include "jpeg4.h"
#include "jpeg5.h"
TFT_eSPI tft = TFT_eSPI(); // Invoke custom library
void setup(){
    Serial.println("Start");
    tft.init();
    tft.setRotation(3);
    tft.setSwapBytes(true);
  tft.fillCircle(120, 120, 118, TFT_GREEN);
  tft.fillCircle(120, 120, 110, TFT_BLACK);
void loop(){
   tft.pushImage(0, 0,  320, 240, jpeg1);
    delay(150);
    tft.pushImage(50, 50,  150, 150, jpeg2);
    delay(150);
    tft.pushImage(0, 0,  320, 240, jpeg3);
    delay(150);
    tft.pushImage(0, 0,  320, 240, jpeg4);
    delay(150);
    tft.pushImage(0, 0,  320, 240, jpeg5);
    delay(150);
Hello
Use an array of pointers
uint16_t const * const jpegs[] = { &jpeg1, &jpeg2, ... };
I need to get better at this stuff, so I'll have a go just to see what I get wrong!
const unsigned short * jpeg[5] = {jpeg1, jpeg2, jpeg3, jpeg4, jpeg5};
@guix why is the & needed? The name of the array is already a pointer, isn't it?
Thanks.
the new code: missed '*'? same result.
  uint16_t const * const jpegs[5] = { &jpeg1, &jpeg2, &jpeg3, &jpeg4, &jpeg5};
  for (int k = 0; k < 5; k++) {
    tft.pushImage(0, 0,  320, 240,  const jpegs[5]);
    delay(150);
got ERROR at the array line:
Arduino: 1.8.19 (Windows 7), Board: "ESP32 Dev Module, FTDI Adapter, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, Core 1, Core 1, None, Disabled"
ILI9341_Images_GD:9:76: error: cannot convert 'const short unsigned int (*)[76800]' to 'const uint16_t* const' {aka 'const short unsigned int* const'} in initialization
E:\ENGINEERING\DIY\Electronic\ESP32\good\ILI9341_Images_GD\ILI9341_Images_GD.ino: In function 'void loop()':
ILI9341_Images_GD:51:38: error: expected primary-expression before 'const'
exit status 1
option enabled in File -> Preferences.
Thanks.
same as above.
BTW: and the '[76800]' in the error message is the length of the image data.
   const unsigned short * jpeg[5] = {&jpeg1, &jpeg2, &jpeg3, &jpeg4, &jpeg5};
       tft.pushImage(0, 0,  320, 240, * jpeg[k]);
      delay(150);
error:
ILI9341_Images_GD:41:77: error: cannot convert 'const short unsigned int (*)[76800]' to 'const short unsigned int*' in initialization
ILI9341_Images_GD:44:48: error: no matching function for call to 'pushImage(int, int, int, int, const short unsigned int&)'
In file included from E:\ENGINEERING\DIY\Electronic\ESP32\good\ILI9341_Images_GD\ILI9341_Images_GD.ino:1:
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\TFT_eSPI_ILI9341/TFT_eSPI.h:561:12: note: candidate: 'void TFT_eSPI::pushImage(int32_t, int32_t, int32_t, int32_t, uint16_t*)' <near match>
   void     pushImage(int32_t x, int32_t y, int32_t w, int32_t h, uint16_t *data);
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\TFT_eSPI_ILI9341/TFT_eSPI.h:561:12: note:   conversion of argument 5 would be ill-formed:
ILI9341_Images_GD:44:39: error: invalid conversion from 'short unsigned int' to 'uint16_t*' {aka 'short unsigned int*'} [-fpermissive]
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\TFT_eSPI_ILI9341/TFT_eSPI.h:566:12: note: candidate: 'void TFT_eSPI::pushImage(int32_t, int32_t, int32_t, int32_t, const uint16_t*)' <near match>
   void     pushImage(int32_t x, int32_t y, int32_t w, int32_t h, const uint16_t *data);
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\TFT_eSPI_ILI9341/TFT_eSPI.h:566:12: note:   conversion of argument 5 would be ill-formed:
ILI9341_Images_GD:44:39: error: invalid conversion from 'short unsigned int' to 'const uint16_t*' {aka 'const short unsigned int*'} [-fpermissive]
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\TFT_eSPI_ILI9341/TFT_eSPI.h:571:12: note: candidate: 'void TFT_eSPI::pushImage(int32_t, int32_t, int32_t, int32_t, uint8_t*, bool, uint16_t*)' <near match>
   void     pushImage(int32_t x, int32_t y, int32_t w, int32_t h, uint8_t  *data, bool bpp8 = true, uint16_t *cmap = nullptr);
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\TFT_eSPI_ILI9341/TFT_eSPI.h:571:12: note:   conversion of argument 5 would be ill-formed:
ILI9341_Images_GD:44:39: error: invalid conversion from 'short unsigned int' to 'uint8_t*' {aka 'unsigned char*'} [-fpermissive]
exit status 1
I don't think that * should be there.
Thanks.
I didn't put '*' first, put then got same error.
actually, just one line code inside loop const unsigned short * jpeg[5] = {&jpeg1, &jpeg2, &jpeg3, &jpeg4, &jpeg5}; got same compiling error.
auto jpeg[5] = {jpeg1, jpeg2, jpeg3, jpeg4, jpeg5};
Thanks.
got ERROR:
E:\ENGINEERING\DIY\Electronic\ESP32\good\ILI9341_Images_GD_ls\ILI9341_Images_GD_ls.ino: In function 'void loop()':
ILI9341_Images_GD_ls:57:13: error: 'jpeg' declared as array of 'auto'
ILI9341_Images_GD_ls:57:18: error: 'jpeg1' was not declared in this scope
ILI9341_Images_GD_ls:57:25: error: 'jpeg2' was not declared in this scope
ILI9341_Images_GD_ls:57:32: error: 'jpeg3' was not declared in this scope
ILI9341_Images_GD_ls:57:39: error: 'jpeg4' was not declared in this scope
ILI9341_Images_GD_ls:57:46: error: 'jpeg5' was not declared in this scope
ILI9341_Images_GD_ls:62:21: error: 'pict' was not declared in this scope
     Serial.println( pict[1]);
E:\ENGINEERING\DIY\Electronic\ESP32\good\ILI9341_Images_GD_ls\ILI9341_Images_GD_ls.ino:62:21: note: suggested alternative: 'pict5'
                     pict5
exit status 1
Post a github link to where you got those six .h files.
yes:
An array of pointers:
const uint16_t *jpgArray[] = {&jpeg1[0], &jpeg2[0], &jpeg3[0], &jpeg4[0], &jpeg5[0]};
Great!
that works well.
many thanks to you gfvalvo.
Ok, you got it, well done! But my suggestion was
and your (correct) suggestion is
"unisgned short" is the same as uint16_t, I'm pretty sure, at least on AVR.
So the only other "difference" is &jpeg1[0] versus jpeg1.
&jpeg1[0] is a pointer to an int
jpeg1 is a pointer to an array of int
In reality, they would have the same value.
Is that right?
but different types...
It may has the same numerical values, but the fact that it types are different has some consequences. For example, if you increment &jpeg1[0] it will jump to the next member of the array, but if you increment jpeg1, it will jump over the whole array etc.
edited:
To be correct your line should be
const unsigned short ** jpeg[5] = {jpeg1, jpeg2, jpeg3, jpeg4, jpeg5};
While &jpeg1[0] and jpeg1 are indeed of different types, the types of the elements of array jpeg are the same (uint16_t const*) for the examples shown in post #15.
A type preserving array of pointers to arrays may look something like this,
uint16_t const (* const jpeg[])[76800] {&jpeg1, &jpeg2, &jpeg3, &jpeg4, &jpeg5};
which can be used as follows:
Serial.println((*jpeg[0])[0]);  // First element of first JPG.
Serial.println((*jpeg[1])[1]);  // Second element of second JPG.
I kept trying different combinations, but couldn't get that data type right.
Perhaps have the compiler do it for us:
decltype(jpeg1) * const jpgArrayrr[] = {&jpeg1, &jpeg2, &jpeg3, &jpeg4, &jpeg5};
then:
  Serial.println((*jpgArrayrr[0])[0], HEX);  // First element of first JPG.
  Serial.println((*jpgArrayrr[1])[1], HEX);  // Second element of second JPG.
