something strange going on with cortexM0 i.e. seeed xiao or adafruit qt py..
arrays dont work.. I am using plain ol code but cant make a simple array work..
everything compiles, just doesnt work at runtime.. get crazy results.. does anyone have gone thru this and figured it out?? regards--
Code?
int16_t scanVitals(){
uint32_t adc=0;
const uint32_t OFFSET=300;
const int16_t comp=540; //compensate for high current pulling up voltages .1v per amp..approx
int16_t WTTS=0;
volatile static int32_t pvv[] ={0,0,0,0,0,0,0,0,0,0,0,0};
volatile static int32_t pvi[] ={0,0,0,0,0,0,0,0,0,0,0,0};
volatile static int32_t battv[]={0,0,0,0,0,0,0,0,0,0,0,0};
//memcpy(pvv, sizeof(pvv));
int16_t x=0;
static int16_t y=0;
int16_t z=0;
y++;
if(y>=10)y=0; //array loop cntr
//get PVcurrent FIRST
for(x=0; x<=5; x++){adc=analogRead(PViIN);}
adc=0;
for(x=0; x<=20; x++){adc+=analogRead(PViIN);}
if(adc>=OFFSET)adc-=OFFSET; //subt offset
pvi[y]=adc/270; //PVi= scale factor
PVi=0;
for(y=0; y<=9; y++){PVi+=pvi[y];}
PVi=PVi/10;
//PVv
for(x=0; x<=5; x++){adc=analogRead(PVvIN);}
adc=0;
for(x=0; x<=20; x++){adc+=analogRead(PVvIN);}
adc=adc-(adc/comp)*(PVv/100);
pvv[y]=adc/54; //PVv=scale factor
PVv=0;
for(y=0; y<=9; y++){PVv+=pvv[y];}
PVv=PVv/10;
//BATTv
for(x=0; x<=5; x++){adc=analogRead(BATTvIN);}
adc=0;
for(x=0; x<=20; x++){adc+=analogRead(BATTvIN);}
battv[y]=adc/54; //BATTv= scale factor
BATTv=0;
for(y=0; y<=9; y++){BATTv+=battv[y];}
BATTv=BATTv/10;
//calculate BATTi
BATTi=(PVv*PVi)/BATTv;
adc=adc-(adc/comp)*(BATTi/100);
BATTv=adc/54; //BATTv= scale factor
for(x=0; x<=5; x++){adc=analogRead(TEMP_IN);}
adc=0;
for(x=0; x<=20; x++){adc+=analogRead(TEMP_IN);}
//static int32_t tt=0;
//if(tt!=TPv)Serial.println(TPv);
int16_t TPv=adc/21;
//static int16_t tt=0;
TEMPdeg=calcTemp(TPv);
return (PVv*PVi)/100; //WATTS
So what is happening exactly that is unexpected?
the reads from the arrays are various and nonsense.. not the same results from each array..different results.. I think I am crossing some 4 byte boundary or something like that..
my code was running just fine but the digits were flickering somewhat, so I wanted to slow down the readings and average them using arrays 10 deep to
average out the readings.. bang..no matter what I do, doesnt work.. 5 hrs nowand no idea ...
its nice to have the 48mhz speed that xiao has, but to make it human-friendly to see I wouldlike to slow down the readouts..using arrays seemed like the logical way to do that..
A couple of things...
First time through routine y will be 1, not 0, as you increment it before using it.
static int16_t y=0;
int16_t z=0;
y++;
You use y in a number of for loops, so when returning it will have a high value (for example it will be 10 after completing the for loop below.
On a subsequent call to the routine it will be reset back to 0...
...so these statements will not use the correct index.
uint32_t adc=0;
int16_t WTTS=0;
int16_t x=0;
static int16_t y=0;
int16_t z=0;
y++;
adc=0;
PVi=0;
for(z=0; z<=9; z++){PVi+=pvi[z];}
PVi=PVi/10;
//PVv
adc=0;
PVv=0;
for(z=0; z<=9; z++){PVv+=pvv[z];}
PVv=PVv/10;
//BATTv
adc=0;
BATTv=0;
for(z=0; z<=9; z++){BATTv+=battv[z];}
BATTv=BATTv/10;
//calculate BATTi
adc=0;
int16_t TPv=adc/21;
THANKS.. I setup 'z' to do the averaging and then must have had a brain malfunction and used y..dang..looks like it is working.. many thanks..
