How to use arrays with Arduino?
Hello forum.
Before I posted this question (a really basic one, I am absolutely sure), I read this: http://arduino.cc/de/Reference/Array and http://www.arduino.cc/en/Tutorial/KnightRider
The difference from what I want to do is the initialization of the array. I want to give values to the array inside a cycle, and the example shows an array being read in a cycle. What I tried to do, just to try and put the concept to work in the simplest way possible (and I can't understand why it doesn't work), was this:
int val[1000];
void setup(){
void loop(){
  val[0] = 1;
  val[1] = 5;
  val[2] = 2;
  val[5] = 10;
  Serial.print("val0 = ");
  Serial.println(val[0]);
  Serial.print("val1 = ");
  Serial.println(val[1]);
  Serial.print("val2 = ");
  Serial.println(val[2]);
  Serial.print("val5 = ");
  Serial.println(val[5]);
The code compiles but nothing is printed. If I comment all the array related lines then I can see val0 = val1 = val2 = val5 = val0... as expected. Is there limitation to filling arrays at different zones of the arduino code?
Thanks in advance, I hope the details are enough.
Using 2000 of your 2048 bytes of RAM (on a Uno) may not end well for you. Suggest you trim it down.
Trimmed it down to 500 and all went well. Thanks for the fast answer!
