Greatings, i have a question about to use attachinterrupt(), i didn't have any problems when I only used 1 core (without xTaskCreatePinnedToCore()) here is an example:
const byte interruptPin = 25;
volatile int interruptCounter = 0;
int numberOfInterrupts = 0;
portMUX_TYPE mux = portMUX_INITIALIZER_UNLOCKED;
void IRAM_ATTR handleInterrupt() {
portENTER_CRITICAL_ISR(&mux);
interruptCounter++;
portEXIT_CRITICAL_ISR(&mux);
Serial.println("Monitoring interrupts: ");
pinMode(interruptPin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(interruptPin), handleInterrupt, FALLING);
if(interruptCounter>0){
portENTER_CRITICAL(&mux);
interruptCounter--;
portEXIT_CRITICAL(&mux);
numberOfInterrupts++;
Serial.print("An interrupt has occurred. Total: ");
Serial.println(numberOfInterrupts);
In the previous code the interrupt works well, but when i create some task in the cores i can't attach the interrupt, here is my code:
interruptCounter++;
void sensor_measure(void * parameter){
Serial.print("Task 1 running");
//Also, i tried to attach the interrupt inside task 1
// attachInterrupt(digitalPinToInterrupt(interruptPin), handleInterrupt, FALLING);
void alarm_system(void * parameter){
Serial.print("Task 2 running");
/* if(interruptCounter>0){
interruptCounter--;
//I tried to attach the interrupt before inicialice the task but doesn't work
//Create task 1 in core 0
xTaskCreatePinnedToCore( sensor_measure, "measure", 5000, NULL, 2, &Task1, 0);
//Create task 2 in core 1
xTaskCreatePinnedToCore( alarm_system, "alarm", 50000, NULL, 2, &Task2, 1);
Bassically my question is: How can i attachinterrupt in specific core? I read the documention about interruptions (Interrupt allocation - ESP32 - — ESP-IDF Programming Guide latest documentation ) but i couldn't solve my problem, if anyone can give me a example how to use it I really will apreciate.
Thank you.
The interrupt gets attached to a pin, GPIO, not a core. The interrupt handler should be put into IRAM.
This ISR,
void IRAM_ATTR onTimer()
BaseType_t xHigherPriorityTaskWoken;
xEventGroupSetBitsFromISR(eg, OneMinuteGroup, &xHigherPriorityTaskWoken);
} // void IRAM_ATTR onTimer()
uses freeRTOS to trigger several tasks upon execution, event triggers work well in a ISR.
This volatile int interruptCounter = 0; would be better protected with a Semaphore.
gcjr
July 10, 2022, 6:37pm
3
are GPIOs accessible to both cores? if so, which core handles the interrupt?
The same core as the code that called attachInterrupt() was running in.
Typically, if using the Arduino AttachInterrupt thingy in setup() the interrupt will be attached to core1.
If assigning the interrupt in a task
common task congifuration
void taskthingy( void *pvparemeters )
//assign interrupt here and interrupt will go onto the core the task has been assigned to.
for (;;)
GPIO's are accessible by Core0, Core1, and the ULP.
Do you have an example assign interrupt inside in a task ussing AttachInterrupt()? Like your code
for (;;)
Something like this. Compiles but untested.
void attachInterruptTask(void *pvParameters);
void isr();
const uint8_t interruptPin = 25;
const uint8_t core = 0; // ISR Will run on Core 0
xTaskCreatePinnedToCore(attachInterruptTask, "Attach Interrupt Task", 2000, NULL, 6, NULL, core);
void attachInterruptTask(void *pvParameters) {
attachInterrupt(digitalPinToInterrupt(interruptPin), isr, FALLING);
vTaskDelete(NULL);
void IRAM_ATTR isr() {
Thank you so much, your code works great! I made little changes and this is my finally code and the solution of my question:
//Connection
//Button pin 1 -> GND
//Button pin 2 -> GPIO13
void isr();
const uint8_t interruptPin = 13;
//Create Task running in core 0
xTaskCreatePinnedToCore(attachInterruptTask, "Attach Interrupt Task", 2000, NULL, 6, NULL, 0);
//Create Task Running un core 1
xTaskCreatePinnedToCore( alarm_system, "alarm", 2000, NULL, 2, NULL, 1);
//Set BTN as input pull-up
//Attach Interrupt in core 0
while(true){
Serial.println("Task 1 Running");
vTaskDelete(NULL);
void alarm_system(void *pvParameters) {
while(true){
Serial.println("Task 2 running");
vTaskDelete(NULL);
Serial.println("BTN pressed");
Output:
I hope this code helps another people since I saw a lot of questions about this issue
system
Closed
January 6, 2023, 9:32pm
11
