I want to use it with my LEORX NEMA 17 Stepper. The problem is that the wires are too thin to fit into the female jumper cable of the stepper. How can I solve this problem? Should I buy a slip ring with AWG 26 wires? Should I solder a pin header onto the wires?
But do note, the motor is rated for 2A but without circuitry it will NOT limit itself to 2A and draw more if you block it or overload it. And note that even 2A is right on the boarder of the slip ring.
