how to use basic EEPROM ?
@SunilV - maybe people would start taking you seriously if you read how to post code correctly.
And, ease up on the ad hominems.
AWOL
I don't want anyone to take me seriously ha ha.
I just try to engage here at a meaningful level and contribute my two cents
worth of ideas. I have no appetite for
slander, belittle or make unprofessional comments like that
GRUMPY boy! who seems to have lost in cyber space.
if anything goes wrong the BIOS might be affected
What BIOS would that be ? The Arduino does not have a BIOS
Don't worry, I won't
I am sorry, but you failed
@ SunilIV. (What happened to SunilI through SunilIV ?). If you don't use code tags, it may end up mangled nonsense like in reply #3, which is confusing to the newbies you think you're trying to help.
It greatly devalues your two cents.
UKHeliBob
well BIOS or whatever system used in the chip in ARDUINO IDE. the definition I had in above post was just a cut and paste. if a code that goes haywire like an infinite loop might damage IDE (?)
an expert can confirm this. run time programming through PAGING is a better and safe way.
AWOL
it devalues to 1 cent. the difference of my code to Geofmen is that he uses a switch and
I use a mic.
probably, a person who understands programming will pick this quickly but as you
say a beginner might not. as far as I am concerned I have comments
at each line of code. if you find that nonsensical well that's your problem.
as I say you need a bit of grey matter to engage in programming.
I think we have drifted too far from the core issue here.
hey what happened here..more discussion...
don't argue each other lets help each other...peace..
and I need your help in my code..anyone..thanks...
geofmen:
We can't see your code.
