How to use classes (objects in Arduino if possible
Is it possible to use class in Arduino? Even simple toy problem fails..
// try to implement class in Arduino, saw Processing example in
// processing.org/learning/tutorials/objects/
// simple test fails on error, is use off Class
class test{
public: //public otherwise error: test::test private
int i; // a variable
test(){ //the constructor
i=0;
void addone(){ //a function
i=i+1;
}; // undocumented semicolon otherwise error:
void setup(){
// "test mytest;" compiles ok, next statement now error:
// conversion from 'test*' to non-scalar type 'test' requested
test mytest = new test();
void loop(){
try it without the new keyword
Mr mem,
Ok, thank you for the quick response. Compiles and all is working.
wim4you
// toy Arduino program for testing class
// Processing example in http://processing.org/learning/tutorials/objects/
class test{
i=0;
i=i+1;
// no new today .. thanks to mr mem from arduino forum
test atest1 = test();
test atest2 = test();
//rest is some testing to PC
void setup(){
void loop(){
//small test seems to work allright
Serial.print("atest1.i : ");
atest1.addone();
Serial.println(atest1.i);
// does it work with 2 variables: yes
Serial.print("atest2.i : ");
atest2.addone();
atest2.addone();
// can you assign and read: yes
if (atest2.i >= 20) {atest2.i=1;}
Serial.println(atest2.i);
