I'm using Ardunio IDE 1.8.16 on Windows 10.
esp32 version: 2.0.1
How to use develop tools to add a macro defination in sdkconfig.h?
e.g. #define CONFIG_DISABLE_HAL_LOCKS 1
Is there a solution?
This addresses the file:
Here developers use Platformio IDE, and IDF , but actually I use Arduino IDE.
Same concept ...
A library or core is downloaded and a zillion files get installed. A configuration file, once located, can almost always be edited with notepad or notepad++ or whatever you normally use for flatfiles.
You are right. As a developer it's easy. But I want common user to config it easily.
So I want to know if there is a tool to config it rather than modify the .h file directly.
No.
But you could write one. If on Windows, a little VBA is all that is required. There is a VBA compiler.
For Linux, there are editors and scripting.
You could even do it in Excel or Word.
I suspect PowerShell could be used. Google it.
Also, FreeBASIC
Thanks a lot!
