How to use DHT22 in a function?
Library Example code works:
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain, Dew Point added by W0FMS
#include <DHT.h>
#define DHTPIN 7 // what pin we're connected to
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
DHT dht(DHTPIN, DHTTYPE);
Serial.println("DHTxx test!");
dht.begin();
// Wait a few seconds between measurements.
delay(2000);
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
// Read temperature as Celsius
float t = dht.readTemperature();
// Read temperature as Fahrenheit
float f = dht.readTemperature(true);
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t) || isnan(f)) {
Serial.println("Failed to read from DHT sensor!");
// Compute heat index
// Must send in temp in Fahrenheit!
float hi = dht.computeHeatIndex(f, h);
double VaporPressureValue = h * 0.01 * 6.112 * exp((17.62 * t) / (t + 243.12));
double Numerator = 243.12 * log(VaporPressureValue) - 440.1;
double Denominator = 19.43 - (log(VaporPressureValue));
double DewPoint = (Numerator / Denominator);
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t");
Serial.print("Temperature: ");
Serial.print(t);
Serial.print(" *C ");
Serial.print(f);
Serial.print(" *F\t");
Serial.print("Heat index: ");
Serial.print(hi);
Serial.println(" *F");
Serial.print("Dewpoint ");
Serial.print(DewPoint);
Serial.print(((9.0 / 5.0) * DewPoint) + 32);
Serial.println(" *F\n");
When I try this code with the getDHT22; function I get no return values:
// Modified by Techno500
#include <DHT.h>
float h;
float t;
float f;
float hi;
float DewPoint;
dht.begin();
getDHT22();
Serial.print(h);
Serial.print(t);
Serial.print(f);
Serial.print(hi);
float getDHT22() {
delay(2000);
return(h,t,f,hi,DewPoint);
I get all zero values for return variables.
Is it possible to have a function like getDHT22 and return valid variable values?
This is the origin of the DHT library used: GitHub - adafruit/DHT-sensor-library: Arduino library for DHT11, DHT22, etc Temperature & Humidity Sensors
William
  return (h, t, f, hi, DewPoint);You can only return a single value from a function.
You can actually have a function return multiple values indirectly using a struct.
struct MyReadings
   float humidity;
   float temperature;
MyReadings m = GetReadings();
Serial.println(m.temperature);
struct MyReadings GetReadings()
  MyReadings r;
  r.temperature = 0;
  return r;
@b4ip
Thank you for the reply. My first time using struct; still do not understand how to apply it to the DHT22 function. Here is what I attempted:
//My failed attempt to use struct.
#include <DHT.h>
float h;
float t;
float f;
float hi;
float DewPoint;
dht.begin();
getDHT22();
Serial.print(m.h);
Serial.print(" %t");
Serial.print(m.t);
Serial.print(m.f);
Serial.print(" *Ft");
Serial.print(m.hi);
Serial.print(m.DewPoint);
Serial.println(" *Fn");
float getDHT22()
 delay(2000);
 MyReadings r;
 r.h = 0;
 r.t = 0;
 r.f = 0;
 r.hi = 0;
 r.DewPoint = 0;
    return r;
Need help understanding how to apply struct to return five float variables.
William
At some point you will find that “delay” is a bad way to code. This will lead you to having to use millis timers to get updates from the dht sensor. In the end you will find that storing the readings as a global works best (easiest) so you could skip a few steps and just do that.
try this example
#include <DHT.h>
float h = 0;
float t = 0;
float f = 0;
float hi = 0;
double DewPoint = 0;
unsigned long previousMillis = 0;
  Serial.println("waiting first read");
  dht.begin();
  if (currentMillis - previousMillis > 2000)
  { //every 2 seconds this is true and readings are updated
    takeReadings();
    showReadings();
void takeReadings() {
void showReadings() {
  Serial.println("Humidity: ");
  Serial.print(h);
  Serial.print(t);
  Serial.print(f);
  Serial.print(hi);
@gpop1
Example presented does not compile. Was this the code you intended for me to try?
I am unable to figure out how to get multiple float variables out of function. Function is "getDHT22()" which produces the readings (global variables). I need the five variables in two other functions; one for logging and one to for Ethernet function.
@b4ip
You can actually have a function return multiple values indirectly using a "struct."
I am struggling to understand the use of "struct" for the purpose of returning multiple values. So far, my attempts have failed to compile.
Since the function writes to global variables, there is no need for the function to return anything.
Except they are not, You are creating local variables in the function with the same names as the global variables. Stop doing that.
Either make the variables globals, or make them part of a struct returned by the function.
Not a helpful description
My apologies… Global variables worked without needing struct!
#include "DHT.h"
// NOTE: If using a board with 3.3V logic like an Arduino Due connect pin 1
// to 3.3V instead of 5V!
// Initialize DHT sensor for normal 16mhz Arduino
float h;
float t;
float f;
float hi;
double DewPoint;
  Serial.println("DHT22 test!");
  dht.begin();
  getDHT22();
  Serial.print(h);
  Serial.print(f);
  Serial.print(hi);
  Serial.print(" *F ");
  Serial.print("Dew Point: ");
  Serial.print((DewPoint) + (9/5 + 32));
void getDHT22()
  delay(2000);
  double Numerator =243.12 * log(VaporPressureValue) - 440.1;
  DewPoint = Numerator / Denominator;
Thanks to all that have read and those that replied.
William
