I'd like to write data to the Maxim DS2431 EEPROM. The search forwarded me to following posts:
The code that FredPlais posted works perfect for reading the EEPROM but I don't know how to write data to it. I think the command WriteReadScratchPad(...) followed by CopyScratchPad(...) stores data to the DS2431 but I don't really know how to use it. Here again the code:
#include <OneWire.h>
OneWire ds(2); // 1-wire on pin 2
byte addr[8]; // Contains the eeprom unique ID
void setup(void)
void loop(void)
byte i;
byte dat[13];
SearchAddress(addr);
dat[0] = 0x01;
dat[1] = 0x02;
dat[2] = 0x03;
dat[3] = 0x04;
dat[4] = 0x05;
dat[5] = 0x06;
dat[6] = 0x07;
dat[7] = 0x08;
WriteRow(0,dat);
ReadAllMem(); //print all mem content
while(1);
void SearchAddress(byte* address) //Search for address and confirm it
int i;
if ( !ds.search(address))
Serial.print("No device found.\n");
ds.reset_search();
delay(250);
return;
Serial.print("ADDR= ");
for( i = 0; i < 8; i++)
Serial.print(address[i], HEX);
Serial.print(" ");
if ( OneWire::crc8( address, 7) != address[7])
Serial.print("CRC is not valid, address is corrupted\n");
return;
if ( address[0] != 0x2D)
Serial.print("Device is not a 1-wire Eeprom.\n");
return;
void WriteReadScratchPad(byte TA1, byte TA2, byte* data)
int i;
ds.reset();
ds.select(addr);
ds.write(0x0F,1); // Write ScratchPad
ds.write(TA1,1);
ds.write(TA2,1);
for ( i = 0; i < 8; i++)
ds.write(data[i],1);
ds.reset();
ds.select(addr);
ds.write(0xAA); // Read Scratchpad
for ( i = 0; i < 13; i++)
data[i] = ds.read();
void CopyScratchPad(byte* data)
ds.reset();
ds.select(addr);
ds.write(0x55,1); // Copy ScratchPad
ds.write(data[0],1);
ds.write(data[1],1); // Send TA1 TA2 and ES for copy authorization
ds.write(data[2],1);
delay(25); // Waiting for copy completion
//Serial.print("Copy done!\n");
void ReadAllMem()
int i;
ds.reset();
ds.select(addr);
ds.write(0xF0,1); // Read Memory
ds.write(0x00,1); //Read Offset 0000h
ds.write(0x00,1);
for ( i = 0; i < 128; i++) //whole mem is 144
Serial.print(ds.read(), HEX);
//Serial.print(" ");
void WriteRow(byte row, byte* buffer)
int i;
if (row < 0 || row > 15) //There are 16 row of 8 bytes in the main memory
return; //The remaining are for the 64 bits register page
WriteReadScratchPad(row*8, 0x00, buffer);
/* Print result of the ReadScratchPad
Serial.print(buffer[i], HEX);
Serial.print(" ");
CopyScratchPad(buffer);
I hope you can help me solving this probblem.
Thanks in advance.
Tiesl
