How to Use expanded I/O to communicate with some bus devices (TM1637 for ex.)
Hello.
On my little arduino board I have already used all my I/Os for several bus connections.
But I have a lot I/Os more through some port expanders (PCF8574P).
I want to add a TM1637 based 7 segments display and would know if it's possible to use it through the I/Os from the port expander.
My I/Os on my PCF8574P work great but I don't know how to use it as with the arduino pins with the TM1637 librarie. Is it possible?
Thank you for reading (sorry for my english...)
http://wiki.seeed.cc/Grove-4-Digit_Display/
Looks like some kind of serial interface using 1 signal wire.
Any way to swap with another pin and make life easier on yourself?
CrossRoads:
Grove - 4-Digit Display - Seeed Wiki
Thank you for the answer but my question was how to use bus devices on extended I/Os.
Do you know if there is a way to use the extended I/O as classic I/Os?
I don't find how to use the TM1637 libraries (or any bus device) with extended I/Os.
