Breixo
October 27, 2023, 10:03am
1
Again, hi everyone. I have this structure:
struct Settings_s {
char SSID[21]; // Always number of characters + 1 (null)
char PASS[21]; // Always number of characters + 1 (null)
float BlrPWR;
float maxSuppTemp;
float minOutdTemp;
float SetPoint;
float SetBack;
bool NTC0_Instl;
Settings_s Settings = { "ABCDEFGH_1324", "0Abcd1Bcde2Cdef3Defg", +20000.00, +60.00, -5.00, +21.00, +19.00, true};
PUT and SHOW good the entire structure, thanks to you.
I want to do GET and/or UPDATE individually for each member. Once again, excuse my ignorance!.
Why make things complicated ?
Just get() or put() the whole struct and use the individual elements as required.
When using put() or update() only the bytes that have changed are actually written to the EEPROM
Breixo
October 27, 2023, 10:51am
3
Thanks, UKHeeliBob! I knew that I should not rewrite data unnecessarily in the EEPROM. What I didn't know was that by writing (updating) data in bulk, only the data that had changed was updated.
Once again thanks and greetings,
Breixo
October 27, 2023, 12:28pm
4
Sorry, UKHeliBob but when I try to update:
void UPDATE_SETINGS() {
EEPROM.update(EEADDR, Settings);
It appears the following error message:
[../EECTRL.h:132:32: error: no matching function for call to 'EEPROMClass::update(int, Settings_s&)'](C:/Users/xldoc/AppData/Local/Temp/VSM Studio/886f79b6e4c940cda031d1b60b84d861/ARDUINO_MEGA_1/EECTRL.h#131.31)
At the beginning of the sketch I have:
#define EEADDR 0
What am I doing wrong?
You are doing nothing wrong, it is just that update() only works for single byte variables. However, if you use put() then that uses the update() method internally to avoid unnecessary writes to the EEPROM so has the same overall effect
I have made the following sketch based on post #5 @UKHeliBob .
#include<EEPROM.h>
#define EEADDR 0x0010
struct Settings_s
float BlrPWR;
float maxSuppTemp;
float minOutdTemp;
float SetPoint;
float SetBack;
bool NTC0_Instl;
UPDATE_SETTINGS();
Serial.println(Settings.SSID); //shows: ABCDEFGH_1324
memcpy(Settings.SSID, "pBCDEFGH_1324", sizeof Settings.SSID);
Serial.println(Settings.SSID); //shows: pBCDEFGH_1324
void loop() {}
void UPDATE_SETTINGS()
//EEPROM.update(EEADDR, Settings);
EEPROM.put(EEADDR, Settings);
Output:
ABCDEFGH_1324
pBCDEFGH_1324
Breixo
October 27, 2023, 3:54pm
7
Thanks, @UKHeliBob and @GolamMostafa , now I'm out of the jam.
system
Closed
April 24, 2024, 3:55pm
8
