How to use indexOf by an byte array ?
Hi there, I've an question, but couldn't find it anywhere on the web.
I have to convert error codes from an device towards an number.
without using a lot of ifs and else's
byte lookupTable[] =
{0x4481, 0x4541, 0x4542, 0x4543, 0x4544, 0x4545, 0x4546, 0x4547, 0x4548, 0x4549, 0x4582, 0x4583, 0x4584, 0x4585, 0x4586, 0x4587, 0x4588,
 0x45C1, 0x45C2, 0x45C3, 0x45C4, 0x45C5, 0x45C6, 0x45C7, 0x45C8, 0x45C9, 0x45CA, 0x4601, 0x4602, 0x4603, 0x4604, 0x4681, 0x4682, 0x4683,
 0x46C1, 0x46C2, 0x4781, 0x4782, 0x4783, 0x47C1, 0x4881, 0x4882, 0x4883, 0x4884, 0x4885, 0x4886, 0x4887, 0x4888, 0x4889, 0x488A, 0x488B,
 0x488C, 0x488D, 0x488E, 0x4941, 0x4942, 0x4981, 0x49C1, 0x49C2, 0x4A01, 0x4A81, 0x4B01, 0x4B81, 0x4C41, 0x4D01, 0x4D02, 0x4D03, 0x4D04,
 0x4D41, 0x4D42, 0x4D43, 0x4DC3, 0x4E81, 0x4F01, 0x4F02, 0x4F41, 0x4F42, 0x4F43, 0x4F44, 0x4F45, 0x4F46, 0x4F47, 0x4F48, 0x4F49, 0x4F4A,
 0x4F4B, 0x4F4C, 0x4F4D, 0x4F4E, 0x4F4F, 0x4F50, 0x4F51, 0x4F52, 0x4F53, 0x4F54, 0x4F55, 0x4F56, 0x4F57, 0x4F81, 0x5041, 0x5042, 0x5043,
 0x5044, 0x5045, 0x5046, 0x5081, 0x5101, 0x5102, 0x5141, 0x5181, 0x5182, 0x5183, 0x5184, 0x5185, 0x5186, 0x5187, 0x5188, 0x51C1, 0x51C2,
 0x5201, 0x52C1, 0x52C3, 0x52C4, 0x52C5, 0x5301, 0x5302, 0x5303, 0x5304, 0x5305, 0x5306, 0x5307, 0x5308, 0x5309, 0x530A, 0x530B, 0x530C,
 0x530D, 0x530E, 0x530F, 0x5310, 0x5311, 0x5312, 0x5313, 0x5314, 0x5315, 0x5316, 0x5317, 0x5318, 0x5319, 0x5341, 0x5342, 0x5343, 0x5344,
 0x5381, 0x5441, 0x5442, 0x54C1, 0x54C2, 0x54C3, 0x54C4, 0x54C5, 0x54C6, 0x54C7, 0x54C8, 0x54C9, 0x54CA, 0x54CA, 0x54CB, 0x54CC, 0x54CD,
 0x54CE, 0x54CF, 0x5741, 0x5781, 0xD01A, 0xD02A, 0xD03A, 0xD01B, 0xD02B, 0xD03B, 0xD04B, 0xD01C, 0xD02C, 0xD03C};
  int number = lookupTable.indexOf(DATA);
where DATA are the error codes from an device's
sadly enough this code wont work. as far as I know indexOf works only with an String.
this script returns an error on the compiler ( which is of non-class type "byte" )
How can you fit '0x4481' into a byte?
You're going to have to write your own indexOf function. You can use a brute force approach that just cycles through the array, or you could use a modified binary search since the data seem to be in sorted order.
lookupTable is no Class with methods like e.g. Visual Basic has,
you need to write your own search (as said above)
  • linear search is straightforward,
  • seen the size a binary search would be faster,
  • you can save precious RAM by placing the table in PROGMEM
int searchIndex(int value)
  for (int i=0; i< 184; i++)
    if (lookupTable[i] == value)
      return i;
  return -1;
