how to use input
hey guys how to use an input from a device and set the input later in the code as an int and perform if staement the input i want to use is rssi value from hc -05
AT+INQM=1,9,48
AT+INQ
+INQ:1234:56:0,1F1F,FFC0
i got this code from here http://electronics.stackexchange.com/questions/98160/how-to-get-rssi-of-bluetooth-specfically-hc-05/ pls note this is a variable input. thaks in advance :)
Here's a clue.
AT+INQM=1,9,48 AT+INQ +INQ:1234:56:0,1F1F,FFC0
is NOT an int.
If you want to parse that data, you must first tell us how that data is stored. Where IS your code?
Is this the string that is returned by the HC05?
Assuming you are saving that into a char array you can parse the array to pick out the parts you want. There is a parse example in serial input basics.
As usual, you will get much more help if you post your code.
...R
