how to use interrupt wake up after sleep
my program on arduino 1 rev 3 works fine. Pin 2 is pullupped internally when i put at low level pin 2 it resume from sleep and do his job . if i leave it open it goes sleeping.
But i should like to have it sleeping when pin 2 goes down , but arduino uno not works with attachinterrupt triggered HIGH in the istruction attachInterrupt(0, wake, LOW);
so i tryed to put it FALLING or CHANGE but it not resume from sleeping. ( i changed also digitalWrite (sveglia, HIGH) to eliminate pull up having the pin low at program start)
help pleaseeeee... thanks ( sorry for previous topic)
#include <avr/sleep.h>
#define LED 13
#define txrx 6
#define sveglia 2
#define impulsi 5
// Variabili
unsigned long counts = 0;    // Contatore unsigned long delgi impulsi fatti
int numimpulsi = 0;          // impulsi da fare dal contatore
String sknum = "SK:0A5B44"; // identificativo scheda
long intervallo = 1000; // 3 secondi  di ritardo prima che definisca che gli impulsi sono finiti
int temperatura = 0 ;      // variabile temperatura
int tensione = 0;          // variabile tensione carica
int reading = 0;
int flag=0;
unsigned long tempo;
unsigned long tempoprima;
//fine variabili
void setup()  {
   // disable ADC
  ADCSRA = 0;
 digitalWrite (sveglia, HIGH);  // pull-up il pin 2 e' quello che si sveglia se messo a massa
 pinMode (LED, OUTPUT);
 digitalWrite (LED, HIGH);  // awake
  pinMode (txrx, OUTPUT);
 digitalWrite (txrx, LOW);  // abilito trasmettitore
 Serial.println ("INIZIO LED ACCESO");
//setup  contatore impulsi
   pinMode(impulsi, INPUT); digitalWrite(5, HIGH); // pulses on pin-5 = PD5 = T1 pull up pin 5
//  TCCR0A=0; // setup timer-0
//  TCCR0B=0;
//  TIMSK0=0;
  TCCR2A=0; // setup timer-2
  TCCR2B=0;
  TIMSK2=0;
  TCCR1A=0; // setup timer-1
  TCCR1C=0;
  TIMSK1=0;
  GTCCR=0;
Serial.println("PARTENZA CONTEGGIO QUANDO la scheda si sveglia per il pin 2 e ARRIVANO IMPULSI  ");
 digitalWrite (txrx, HIGH);  // disabilito trasmettitore
  TCNT1=0; //azzero contatore
}  // fine setup
if (digitalRead (2)== HIGH)      // se il pin 2 e' a 1 fisso come sempre perche' e' pullup allora sleep (%%%%%% da cambiare deve andare a 0 fisso)
     { sleepNow();}
      else {    // se il pin 2 e' a 0 fisso perche' ce lo metto allora parte la routine di wakeup e continua il void loop passando qui
    // ROUTINE CONTROLLO IMPULSI
  tempo=millis();
  reading = digitalRead(5);  //se il pin degli impusi e' visto ogni tanto a 1 parte il reading high
                    //   IL CONTATORE  E' PARTITO
                    if (reading == HIGH) {
                                      tempoprima=tempo;
                                      digitalWrite(LED, HIGH); //  ACCENDE LED sto contando
                                      TCCR1B=0; // stop count devo fermare per leggere
                                      counts = TCNT1; // read count PUNTO ESSENZIALE LETTURA DEL CONTEGGIO
                                      TCCR1B=7; // start count riparte il contatore
                                      flag=1;
                                      }// chiusura if reading high
                                      // FINE ROUTINE CHE LEGGE IMPULSI ****************************
                    //   IL CONTATORE E' FERMO O HA FINITO DI CONTARE PERCHE' SONO FINITI GLI IMPULSI
                    if (reading == LOW) {
                                     // SE IL TEMPO DI ATTESA E' FINITO
                                     if(flag==1 && (tempo-tempoprima) > intervallo)      {
        digitalWrite(LED , LOW); //LED SPENTO conteggio disattivato
        flag=0;
        //  CONTROLLO tensione e temperatura
        temperatura = analogRead(0); // controlla la temperatura pin 0
        tensione = analogRead(1); // controlla la tensione pin 1
        // FINE CONTROLLO
        delay(5);
        Serial.println (sknum);
        Serial.print ("IMP=");
        Serial.println(counts);
        Serial.print ("GRADI ");
        Serial.println(temperatura);
        Serial.print ("VOLT ");
        Serial.println(tensione);
        delay(60);
        digitalWrite (txrx, HIGH);  // disabilito trasmettirore
        // AGGIUNGI se tensione e' minore di tot manda allarme e si ferma
        }//chiusura if flag
              }// chiusura if digitalread 2
}//chiusura void loop
// END VOID LOOP
// interrupt service routine
void wake()
  sleep_disable();         // first thing after waking from sleep:
  detachInterrupt (0);     // stop many many interrupts
// fine interrupt service routine
// sleep routine
void sleepNow()
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);   // sleep mode is set here
  sleep_enable();          // enables the sleep bit in the mcucr register
// turn off brown-out enable in software
  MCUCR = _BV (BODS) | _BV (BODSE);
  MCUCR = _BV (BODS);
   delay(5);
  Serial.println("ENTRO IN SLEEP LED SPENTO");
    delay(60);
  digitalWrite (LED, LOW);  // asleep
  sleep_mode();            //IN QUESTO MOMENTO E' IN SLEEP FERMO QUI
// PUNTO DI RIENTRO DELLA ROUTINE AL WAKE UP quando parte interrupt 0 cioe'pin 2  basso
  digitalWrite (LED, HIGH);   // RISVEGLIO ACCENDO LED
  Serial.println("SONO TORNATO! LED ACCESO");
      delay(60);
// end of sleepNow
I think if you look in the section of the datasheet about sleeping you will find that is says you can't use an edge-triggered interrupt (RISING, FALING, or CHANGE) to wake from sleep.
Easiest solution is a hardware solution: put an inverter on the signal to change it from an Active Low signal to an Active High signal. This can be done with a transistor and a few resistors or can be done with an inverter chip.
johnwasser:
ok , it looks fine with a transistor because i am in energy harvesting situation an powering arduino with a 20 ma generator ( really low power) . do you know any other way other than a simple zener to supply 5 v without current consumption?
There is NO way to supply voltage without supplying current, too.
