How to use IR Dump data to re-create an IR code on demand
I tried to find an answer to this on Google, but nothing seems to address specifically what I'm trying to find out.
Here is some output from the IRrecvDumpV2 example sketch from the IRremote library. This comes from a remote that is used on a Cisco brand cable TV receiver. Notice the brand it's detecting is Sanyo ... there is no sender function in the IRremote library for Sanyo, only a decoder ... so how would I use the simpler hex codes to re-create these codes accurately? I'm trying to get away from using the larger RAW int arrays to avoid the memory issues since I want to store and recall over 50 of these codes.
IN: Timing[47]:
Name Code: 366932
IN: Code      : 366932 (23 bits)
IN: Encoding  : SANYO
IN: + 750, -2650     + 650, -2650     + 700, - 900     + 750, - 950
IN: +3200, -3400     + 750, -2550     + 750, -2600     + 750, - 950
IN: + 700, -2650     + 700, -2650     + 700, - 900     + 750, -2650
IN: + 700, -1000     + 700, -2600     + 700, -2700     + 650, - 950
IN: + 700, - 950     + 700, - 900     + 750, -2600     + 750, - 950
IN: + 700, -1000     + 700, -2600     + 750, - 950     + 700
IN: unsigned int  data = 0x366932;
IN: Timing[47]:
Name Code: 366133
IN: Code      : 366133 (23 bits)
IN: + 750, -2500     + 800, -2550     + 800, - 850     + 800, - 900
IN: +3300, -3350     + 800, -2500     + 850, -2500     + 800, - 950
IN: + 800, -2550     + 750, -2550     + 800, - 900     + 750, - 900
IN: + 750, - 900     + 750, -2550     + 800, -2500     + 850, - 950
IN: + 800, - 800     + 850, - 850     + 800, -2550     + 800, - 900
IN: + 700, - 950     + 700, -2550     + 800, -2550     + 800
IN: unsigned int  data = 0x366133;
IN: Timing[47]:
Name Code: 37e902
IN: Code      : 37e902 (23 bits)
IN: +3250, -3350     + 800, -2600     + 700, -2550     + 800, - 900
IN: + 750, -2600     + 700, -2600     + 750, - 900     + 750, -2600
IN: + 750, -2650     + 700, -2550     + 800, -2500     + 850, -2600
IN: + 800, - 850     + 800, - 900     + 750, - 900     + 750, - 950
IN: + 750, - 900     + 750, - 900     + 800, -2550     + 750, - 900
IN: + 700, - 950     + 750, -2550     + 750, - 900     + 800
IN: unsigned int  data = 0x37e902;
Thank you,
Mike
Unfortunately, whoever added the Sanyo decoder to IRremote did not include an ENCODER. That should be fairly easy to do since the decoder says that Sanyo is very similar to Sony.
johnwasser:
OK, so what needs to be done to make the encoder?
EasyGoing1:
My guess, based on their comment, is that you would take the Sony encoder and drop it in the Sanyo file, change the name to sendSanyo(), and change this part of IRremote.h:
#define DECODE_SANYO         1
#define SEND_SANYO           0 // NOT WRITTEN
