How to use LCD and Ethernet Shield together?
Hi, I would like to combine these 2 elements (LCD and Ethernet). I wanted the 16x2 lcd (Powertip PC1602c) to display the analog value obtained from the web. I am able to run the codes separately. It does works for me. However, when I wanted the LCD to display the value when the Ethernet is running, I am not able to do so. I obtained a line of black boxes instead of "analog value".
I have connected my LCD pins to 2,3,5,6,7,9 which does not intersect with the Ethernet pins 4, 10-13.
I am currently testing it with the webserver code:
Web Server
A simple web server that shows the value of the analog input pins.
using an Arduino Wiznet Ethernet shield.
Circuit:
  • Ethernet shield attached to pins 10, 11, 12, 13
  • Analog inputs attached to pins A0 through A5 (optional)
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
#include <LiquidCrystal.h>
#include <SPI.h>
#include <Ethernet.h>
LiquidCrystal lcd(2, 3, 5, 6, 7, 9);
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,123,3);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
// set up the LCD's number of columns and rows:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
lcd.begin(16, 2);
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
// listen for incoming clients
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("");
client.println("");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
** lcd.print("analog input");**
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("
client.println("");
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disonnected");
Did I insert the code at the wrong line or have I missed out any code?
Thanks in advance for your time.
What codes?
Try printing something to the lcd WITHOUT connecting to the server.
Also, try posting your code correctly!
