Hello,
I got library prayertime.h from https://github.com/asmaklad/Arduino-Prayer-Times.
somehow if upload using board esp32, appear on serial monitor value is zero. see below.
but if uploaded with board esp8266 it's working.
here code
#include <stdio.h>
#include <Wire.h>
// get this library from https://github.com/PaulStoffregen/Time
#include <TimeLib.h>
#include "PrayerTimes.h"
double times[sizeof(TimeName)/sizeof(char*)];
void p(char *fmt, ... ){
char tmp[128]; // resulting string limited to 128 chars
va_list args;
va_start (args, fmt );
vsnprintf(tmp, 128, fmt, args);
va_end (args);
Serial.print(tmp);
Serial.println("PTimes:");
int dst=1;
set_calc_method(ISNA);
set_asr_method(Shafii);
set_high_lats_adjust_method(AngleBased);
set_fajr_angle(15);
set_isha_angle(15);
//MEKKA
//float latitude=21.427378;
//float longitude=39.814838;
//get_prayer_times(year(), month(), day(), latitude, longitude, dst, times);
get_prayer_times(2015, 5, 8, 46.9500f, 7.4458f, 2, times);
Serial.print("YEAR:");
Serial.println(year());
Serial.print("MONTH:");
Serial.println(month());
Serial.print("DAY:");
Serial.println(day());
for (int i=0;i<sizeof(times)/sizeof(double);i++){
char tmp[10];
int hours, minutes;
get_float_time_parts(times[i], hours, minutes);
p("%d \t %10s %s \t %02d:%02d \n\r",i,TimeName[i],dtostrf(times[i],2,2,tmp),hours,minutes);
Serial.print(i);
Serial.print(" \t ");
Serial.print(TimeName[i]);
Serial.print(" \t\t ");
Serial.print(times[i]);
Serial.print(hours);
Serial.print(":");
Serial.print(minutes);
delay(10000);
void getNextPTime(double &pTime, char* pTimeName)
double currTime=hour()+minute()/60.0;
int i;
set_fajr_angle(15);
set_isha_angle(15);
//get_prayer_times(year(), month(), day(), 46.9500, 7.4458, 1, times);
get_prayer_times(year(), month(), day(), 46.9500, 7.4458, 2, times);
for (i=0;i<sizeof(times)/sizeof(double);i++){
if (times[i] >= currTime) break;
if ( (times[i]-currTime) <0 ) {
i=0;
pTime=times[i];
sprintf(pTimeName,"%s",TimeName[i]);
could you help me please?
Thanks
