How to use millis within a for loop [SOLVED]
I understand how to use millis as a replacement for delay except for one part; in for loops. Specifically, I have a chaser with a shift register using hardware SPI but I need to be able to set the delay based on a potentiometer attached to an analog pin and not have to wait the 500 milliseconds before it changes that delay. I've only used millis to blink leds or to start a particular function at certain intervals but nothing like this. I've tried searching but can't seem to find anything helpful. Hoping posting here might be more fruitful.
code:
Maybe some thing like this :
Multithreading/Protothreading
Once you have asked for a delay , you can't really stop in between and change that value . So, my suggestion would be the above link.
linuxgnuru:
code:
GitHub - linuxgnuru/Chaser_spi_analog
Please post the program here to avoid the need to download it.
In general, you will need to remove the for loop and use the the loop() function to do what you want, perhaps updating a variable at intervals and use that variable as an index to an array (just guessing). Using loop() means that you can read the pot and change the interval each time through loop() if necessary.
tgr8db:
But they use delay(20) !!
They should have coded something like this for delaying:
void checking_delay (unsigned long ms)
  unsigned long t = millis () ;
  while (millis () - t < ms)
    check_all_threads () ;
That approach has to be used carefully as a "thread" must never directly of indirectly call check() on
itself (that causes infinite recursion). So the above function can only be used at top level, not
by any of the threads.
Its probably easier to use the standard idiom of loop() checking everything, and the rest of the
code being loop-free (ie state-machines).
linuxgnuru:
As you have not posted your code I can't be more specific, but my thinking goes along the same lines as @UKHeliBob - don't use FOR.
Have you see the demo Several Things at a Time ?
...R
I apologize for not including the code; I was afraid it was too long... anyways, here it is.
#include <SPI.h>
const byte LATCH = 10;
byte data[] = {
  0b00000000,
  0b00000000
unsigned int myDelay = 50;
  SPI.begin();
  pinMode(LATCH, OUTPUT);
  int j;
  int chip;
  myDelay = map(analogRead(A0), 0, 1023, 0, 50);
  // left to right
  for (int i = 0; i < 16; i++)
    if (i < 8)
      chip = 1;
      j = i;
      chip = 0;
      j = i - 8;
    toggle(chip, j);
    delay(myDelay);
    if (i < 8)
      chip = 1;
      j = i;
      chip = 0;
      j = i - 8;
    toggle(chip, j);
    delay(myDelay);
  // right to left
  for (int i = 15; i > -1; i--)
    if (i < 8)
      chip = 1;
      j = i;
      chip = 0;
      j = i - 8;
    toggle(chip, j);
    delay(myDelay);
    if (i < 8)
      chip = 1;
      j = i;
      chip = 0;
      j = i - 8;
    toggle(chip, j);
    delay(myDelay);
void toggle(int chip, int pin)
  bitWrite(data[chip], pin, !bitRead(data[chip], pin));
  digitalWrite(LATCH, LOW);
  SPI.transfer(data[0]);
  SPI.transfer(data[1]);
  digitalWrite(LATCH, HIGH);
I think I would do something like this
if ((millis() - prevMillis >= myDelay) && sequenceDone == false) {
    prevMillis += myDelay;
    if (i < 8)
        chip = 1;
        j = i;
        chip = 0;
        j = i - 8;
    toggle(chip, j);
    i --;
    if (i < 0) {
        sequenceDone = true;
And as you seem to have the same code in 4 different places I would put it in a function.
...R
Yeah, that was a thrown together / copied/pasted code. What I ended up doing is put the analogRead part inside the toggle function. Not perfect, and I'm still working on a millis version...
#include <SPI.h>
#define NUM_CHIPS 3
#define MAX_delay 250
byte data[NUM_CHIPS];
unsigned int myDelay = 500;
  SPI.begin();
  for (int i = 0; i < NUM_CHIPS; i++)
    data[i] = 0b00000000;
  // left to right turn on
  for (int i = 0; i < 2; i++)
    for (int j = 0; j < NUM_CHIPS * 8; j++)
      toggle(j);
      delay(myDelay);
  // right to left
    for (int j = (NUM_CHIPS * 8) - 1; j > -1; j--)
      toggle(j);
      delay(myDelay);
void toggle(int input)
  int chip, pin;
  myDelay = map(analogRead(A0), 0, 1023, 0, MAX_delay);
  // TODO make the down to just a couple of lines
  if (input < 8)
    chip = NUM_CHIPS - 1;
    pin = input;
  else if (input > 7 && input < 16)
    chip = NUM_CHIPS - 2;
    pin = input - 8;
  else if (input > 15 && input < 24)
    chip = NUM_CHIPS - 3;
    pin = input - 16;
  else if (input > 23 && input < 32)
    chip = NUM_CHIPS - 4;
    pin = input - 24;
    SPI.transfer(data[i]);
Ok, I finally got exactly what I was wanting; no delays at all. Thanks to everyone who helped out.
What it does:
It's a simple led chaser a la Knight Rider / Cylon eyes in that one led turns on up to the last and then they turn off from start to end and then repeats in the opposite direction.
I have 3 shift registers (74HC595) connected together with 24 leds. The registers are connected to the Arduino's SPI pins (clock 13, data 11, cs/latch 10) and I have a 10K pot attached to A0.
I wrote the program so any number of chips can be used, well, up to 4 but that can be changed in the if part of the toggle function.
I've been programming since 1995 but just recently got into the whole raspberry pi / odroid / micro-controller realm.
Again, thanks for all the help.
#include <SPI.h>
#define NUM_CHIPS 3
#define MAX_DELAY 250
unsigned int prevMillis = 0;
boolean sequence1Done = false;
boolean sequence2Done = false;
int ctr_a = 0;
int ctr_b = 0;
boolean goingRight = true;
  SPI.begin();
  unsigned int curMillis = millis();
  if (sequence1Done == false)
    if (sequence2Done == true) // end first "for" loop
      if (++ctr_b > 1)
        sequence1Done = true;
    else if ((curMillis - prevMillis >= myDelay) && sequence2Done == false)
      if (goingRight)
        if (ctr_a > NUM_CHIPS * 8)
          // end second "for" loop
          sequence2Done = true;
          ctr_a = 0;
        if (sequence2Done == false)
          toggle(ctr_a++);
        if (--ctr_a < -2)
          ctr_a = (NUM_CHIPS * 8);
          toggle(ctr_a);
    if (goingRight == true)
      goingRight = false;
      goingRight = true;
      ctr_a = 0;
    ctr_b = 0;
  int chip, pin;
  myDelay = map(analogRead(A0), 0, 1023, 0, MAX_DELAY);
  if (input < 8)
    pin = input;
    pin = input - 8;
    pin = input - 16;
    pin = input - 24;
Strictly speaking, all of the timing variables should be unsigned long instead of unsigned int.
Is there a reason why you didn't use shiftOut() to move the data to the SRs a byte at a time ?
Thanks for the unsigned long; I'm gradually converting all of my code to get rid of all delays and am still a bit (pun intended) new to looping / micro-controller programming so I've never ran out of numbers before now.
As for the SPI vs shiftOut, I haven't found anything stating one is better than the other; although one would expect that as SPI is hardware and shiftOut is software, the hardware would be faster albeit with shiftOut you get to pick which 3 pins to use.
Whilst shiftOut() may be slower does it matter in your application ?
I was planning on creating a persistence of vision project with the non-delay route so I figured I'd need the speed SPI offered
