Seeking help on solving this chin scratching problem of how to use one momentary button to turn on power, and be used to also change the buttoncycle case from one neopixel animation to the next.
My thought is to have something similar to a headlamp, when the momentary button is held down, the power goes on and off, while also when you press the same button it changes from flashing neopixels to a different static neopixel for example. I have been finding some idea of various button presses, hold vs press, but not sure how to use those codes yet. The current code I figured may work by having the first case 0 be blank with no neopixels showing and the battery connected would not use energy, however on the serial viewport it shows the code constantly checking the button state, and the battery eventually does use energy doing this. My goal is have the code not drain the battery constantly checking the button state, and or actually close the circuit somehow.
The code is too large for this forum, but parts of it:
// Adafruit_NeoMatrix example for single NeoPixel Shield.
// Scrolls 'Howdy' across the matrix in a portrait (vertical) orientation.
#include <Adafruit_GFX.h>
#include <Adafruit_NeoMatrix.h>
#ifndef PSTR
#define PSTR // Make Arduino Due happy
#endif
#define PIN 6
int LEDperiod = 0;
unsigned long prevLEDtime = 0L;
const int buttonPin = 7 ;
int buttonState = LOW;
int lastButtonState = LOW;
int debounce_count = 0;
int pixelState = 0;
int val = 0;
int showType = 0;
//changed the bounce check = 10 to 0:
int bounceCheck = 0;
byte heart[17][3]={
1,1,1 }
1,1,1 }
1,1,1 }
1,1,1 }
1,1,1 }
1,1,1 }
1,1,1 }
1,1,1 }
1,1,1 }
1,1,1 }
1,1,1 }
1,1,1 }
1,1,1 }
1,1,1 }
1,1,1 }
1,1,1 }
1,1,1 }
// MATRIX DECLARATION:
// Parameter 1 = width of NeoPixel matrix
// Parameter 2 = height of matrix
// Parameter 3 = pin number (most are valid)
// Parameter 4 = matrix layout flags, add together as needed:
// NEO_MATRIX_TOP, NEO_MATRIX_BOTTOM, NEO_MATRIX_LEFT, NEO_MATRIX_RIGHT:
// Position of the FIRST LED in the matrix; pick two, e.g.
// NEO_MATRIX_TOP + NEO_MATRIX_LEFT for the top-left corner.
// NEO_MATRIX_ROWS, NEO_MATRIX_COLUMNS: LEDs are arranged in horizontal
// rows or in vertical columns, respectively; pick one or the other.
// NEO_MATRIX_PROGRESSIVE, NEO_MATRIX_ZIGZAG: all rows/columns proceed
// in the same order, or alternate lines reverse direction; pick one.
// See example below for these values in action.
// Parameter 5 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
// Example for NeoPixel Shield. In this application we'd like to use it
// as a 5x8 tall matrix, with the USB port positioned at the top of the
// Arduino. When held that way, the first pixel is at the top right, and
// lines are arranged in columns, progressive order. The shield uses
// 800 KHz (v2) pixels that expect GRB color data.
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(3, 17, PIN,
NEO_MATRIX_TOP + NEO_MATRIX_LEFT +
NEO_MATRIX_COLUMNS + NEO_MATRIX_ZIGZAG,
NEO_GRB + NEO_KHZ800);
pinMode(buttonPin, INPUT_PULLUP);
matrix.begin();
matrix.setTextWrap(false);
matrix.setBrightness(50);
int x = matrix.width();
int pass = 0;
int state = 0;
unsigned long t = millis();
matrix.fillScreen(0);
// read the state of the switch into a local variable:
if (buttonState = debounceRead(buttonPin));
Serial.print("ButtonState: ");
Serial.println(buttonState);
Serial.print("LastButtonState: ");
Serial.println(lastButtonState);
Serial.print("showPixels: ");
Serial.println(pixelState);
// compare the buttonState to its previous state
if ((LOW == buttonState) && (buttonState != lastButtonState)){
pixelState = (pixelState + 1) % 2;
lastButtonState = buttonState;}
byte debounceRead(int pin)
uint8_t pinState = digitalRead(pin);
uint32_t timeout = millis();
while (millis() < timeout+1)
if (digitalRead(pin) != pinState)
pinState = digitalRead(buttonPin);
timeout = millis();
//loading************************************************************************************************
//START START START START
//BUTTON 1 SOLID OFF----------------------------------------------------------------
switch(pixelState)
case 0: LEDperiod = 10000000L;
//frame1
for(int k=0;k<255;k+=1){//(+10 ADJUSTS SPEED, 10 IS FASTER, 1 IS SLOW)
for(int i=0;i<18;i++){
for(int j=0;j<18; j++){
matrix.setBrightness(0);
if(heart[i][j]==1)
matrix.drawPixel(j, i, matrix.Color(0,0,0));
matrix.show();
//BUTTON 2 FLASH--------------------------------------------------------------------------------
unsigned long now = millis();
switch(pixelState)
case 1: LEDperiod = 10000000L;
for(int k=0;k<255;k+=10){//(+10 ADJUSTS SPEED, 10 IS FASTER, 1 IS SLOW)
if(heart[i][j]==0)
matrix.show();
// FRAME 2
if(heart[i][j]==1)
matrix.drawPixel(j, i, matrix.Color(255,0,0));
matrix.show();
//DELAY
return pinState;
