how to use namespace?
I was trying to test an accelerometer/OLED-display program from
I had installed the jugle libraries for OLED1306 display.
Compiling the sketch posted on instructables I receive the error
scr.flush "scr was not declared in this scope"
Probably it has to do with namespace. I am not an expert in Arduino, unfortunately.
Any suggestion on how to fix?
Probably not
Please post the code that you are trying to compile
Scope has nothing to do with namespace.
Scope can be global or local to a block defined by {}. When it says "not defined in this scope" it means "you forgot to define it, silly."
Namespaces are useful for larger programs, like you might have a color LCD screen and a multi-color LED. The constant YELLOW has different meaning in the two libraries you picked to drive those two devices.
AccelStepper is the only Arduino library I know of in common usage which encourages you to use the namespace. Most others just use distinct names, such as RA8875_YELLOW in the RA8875 LCD library.
Here is the code:
//https://www.instructables.com/id/Interacting-With-an-OLED-and-an-Accelerometer/
#include <JUGL.h>
#include <SPI.h>
#include <Wire.h>
#include <JUGL_SSD1306_128x64.h>
using namespace JUGL;
SSD1306_128x64 driver;
const int xpin = A3; //Assign pin A3 to x
const int ypin = A2; //Assign pin A2 to y
int x, y, x1, y1, r, varx, vary, width, height; //Define variables
int xy [2]; //Array to hold (x,y) coordinate
//Declaration of functions
void Circle(IScreen& scr);
void move_right(IScreen& scr);
void stop_right(IScreen& scr);
void move_left(IScreen& scr);
void stop_left(IScreen& scr);
void move_up(IScreen& scr);
void stop_up(IScreen& scr);
void move_down(IScreen& scr);
void stop_down(IScreen& scr);
void setup(){
IScreen& screen = driver; //Make reference to driver
screen.Begin(); //Initialize screen
width = screen.GetWidth(); //Get width of screen (128)
height = screen.GetHeight(); //Get height of screen (64)
Circle(screen); //Draw circle
void loop(){
x1 = analogRead(xpin); //Read x analog data
y1 = analogRead(ypin); //Read y analog data
if(x1<500){ //Check if sensor is tilted to the right
move_right(screen); //Move ball right
if(varx>=width-1-r ){ //Check if ball reached end of screen
stop_right(screen); //Stop moving
if(x1>520){ //Check if sensor is tilted to the left
move_left(screen); //Move ball left
if(varx=height-1-r){ //Check if ball reached end of screen
stop_up(screen); //Stop moving
if(y1>510){ //Check if sensor is tilted down
move_down(screen); //Move ball down
if(vary<r){ //Check if ball is within boundaries
scr->Flush(); //Display on screen
void stop_left(IScreen& scr){
scr.Clear(); //Clear screen
varx = r; //Update varx
xy[0] = varx; //Store new varx value
scr.FillCircle(Point(5,xy[1]),r); //Draw circle
scr.Flush(); //Display on screen
void move_up(IScreen& scr){
vary += 10; //Move ball 10 pixels up, assign value to vary
xy[1] = vary; //Store new vary value
scr.FillCircle(Point(xy[0],vary),r); //Draw circle
if(varyr){ //Check if ball is within boundaries
void stop_down(IScreen& scr){
vary = r; //Update vary
scr.FillCircle(Point(xy[0],5),r); //Draw circle
scr is undefined in your loop.
Try replacing it with screen.
Also it should probably be
screen.Flush();
instead of
screen->Flush();
Thank you very much Ugolonix,
replacing scr by screen removes the previous error
but now this error occurs:
68: void move_up(IScreen& scr){
"A function definition is not allowed here before '{'token
resources:
You should add a } after this, else you are not closing the loop.
Doesn't help, exactly the same error
Post your current, updated code. USE CODE TAGS!!!!
I missed the </>, sorry.
#include <JUGL.h>
#include <SPI.h>
#include <Wire.h>
void setup(){
void loop(){
  screen.Flush(); //Display on screen
  screen.Clear(); //Clear screen
  screen.FillCircle(Point(5,xy[1]),r); //Draw circle
  screen.FillCircle(Point(xy[0],vary),r); //Draw circle
  screen.FillCircle(Point(xy[0],5),r); //Draw circle
With your code in the Arduino IDE, press ctrl-t to auto-format and adjust indenting. All functions should start on the far left side. Your's don't because you're missing a '}' at the end of one of them.
Now all functions start on the far left side now.
Then, when I use scr instead of screen (screen had been suggested previously) i get the error
line 56: scr.flush "scr was not declared in this scope".
If I change in just that line scr to screen, I get the error
line 74 (if vary) { "vary was not declared in this scope"
#include <JUGL.h>
#include <SPI.h>
#include <Wire.h>
  if (x1 < 500) { //Check if sensor is tilted to the right
    if (varx >= width - 1 - r ) { //Check if ball reached end of screen
  if (x1 > 520) { //Check if sensor is tilted to the left
    if (varx = height - 1 - r) { //Check if ball reached end of screen
  if (y1 > 510) { //Check if sensor is tilted down
    if (vary < r) { //Check if ball is within boundaries
void stop_left(IScreen & scr) {
  scr.FillCircle(Point(5, xy[1]), r); //Draw circle
void move_up(IScreen & scr) {
  scr.FillCircle(Point(xy[0], vary), r); //Draw circle
  if (varyr) { //Check if ball is within boundaries
void stop_down(IScreen & scr) {
  scr.FillCircle(Point(xy[0], 5), r); //Draw circle
What does Line 74 REALLY say?
Apparently, >r was missing in the code from instructables.
I found this
if (varyr>r) { //Check if ball is within boundaries
at this website:
Was that your question?
It does not remove the error.
My money is on the compiler. If it says a variable is not defined / declare, then you have to figure out why it thinks that. So, where in your code the variable 'varyr' defined?
It should read vary not varyr. but fixing that other errors are popping up.
Maybe I should quit for now.
No fun with codes... posted elsewhere.
Thanks for your help.
For some reason, a lot of the Arduino projects on Instructables are very low quality. I'm sure there are some good ones, but you definitely need to take a minute to try to evaluate the source of the information you find online. I find that code on GitHub tends to be of higher quality, though there is certainly some bad code there too.
pert:
You're being charitable.
