How to use nrf24l01 with esp32 s3 / c3
Hi. I just got into microcontrollers and started working on my first project, an transmitter and receiver. I have two nrf24 modules, an esp32 s3 and an esp32 c3. But, unfortunately, nothing is working. This is the code for the transmitter (esp32 s3):
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
void begin(int8_t sck =12, int8_t miso =13, int8_t mosi =11, int8_t ss =10);
RF24 radio(10, 19); // CE, CSN
const byte address[6] = "00001";
  radio.begin();
  radio.openWritingPipe(address);
  radio.setPALevel(RF24_PA_MIN);
  radio.stopListening();
  const char text[] = "Hello World";
  radio.write(&text, sizeof(text));
And this is the code for the receiver (esp32 c3) :
#include <SPI.h>
#include <RF24.h>
void begin(int8_t sck =4, int8_t miso =5, int8_t mosi =6, int8_t ss =7);
RF24 radio(7, 3); // CE, CSN
  radio.begin();
  radio.openReadingPipe(0, address);
  radio.startListening();
  if (radio.available()) {
    char text[32] = "";
    radio.read(&text, sizeof(text));
    Serial.println(text);
It's probably a programming issue, but I cant seem to find it.
Welcome to the forum
The begin() function seems to be missing from your sketches as does a call to it
The begin() function is from the SPI library. The support team from where I bought the board recommended that I use this function. The esp32 s3 doesn't have dedicated pins for SPI, and I need a way to declare them.
The begin() function that you declare in the sketch has no definition and in any case is not the function called by wire.begin()
And the way to address it is with;
SPI.begin();
There are default SPI pins set in the Arduino core for ESP32S3.
To start SPI on an ESP32S3 Dev kit board I can use;
SPI.begin();
the SPI pins I used on a ESP32_S3_DevKit_1 are
// ESP32_S3_DevKit_1 connections
// ESP32_S3 SCK pin GPIO12  to NRF24L01_pin SCK
// ESP32_S3 MISO pin GPIO13  to NRF24L01_pin MISO
// ESP32_S3 MOSI pin GPIO11  to NRF24L01_pin MOSI
// ESP32_S3 SS  pin GPIO 10   to NRF24L01 SS
// ESP32_S3  pin GPIO 9   to NRF24L01 CSN
RF24 radio(10, 9); // CE, CSN pins
  Serial.println("\n\nESP32 > NRF24L01 transmit test");
  radio.begin();
  if (radio.isChipConnected())
    Serial.println("Transmitter NF24 connected to SPI");
  else Serial.println("\n\nNF24 is NOT connected to SPI");
Thank you so much! It's working now. I really appreciate your help. Props to all of you for helping me out!
