How to use numbers with 16 decimal places in arduino?
Please I need your help. I have to visualise numbers of vector x with 16 values after comma. But with this code, I just have 2 numbers.
x(2)=0.66.....But I want to see all x(2)=0.664452880713490 (was calculated by matlab)
float x[10] ;
int r =  4 ;
x[1]= 0.789632145698 ;
for (  int i = 2; i <=10 ; i++) {
      x[i] = r * (x[i-1]*(1 - x[i-1]));
      Serial.println(x[i]); }
A float is 32 bits.
If you're expecting 16 places of decimals, you're out of luck.
When you print a float you can add a second parameter to say how many decimal places should be printed. The default is 2 decimal places
Which Arduino board are you using, because there is a limitation as to how many decimal places are held by a float in any case
This will show 15 digits after the decimal point... but only the first 6 or 7 significant digits are likely to be correct.
Serial.println(x[i], 15); }
i use arduino uno
A 32 bit float has 23 bits of mantissa.
Log base 10 of 2 to the 23rd power is 6.923, so that's how many significant places you can rely on.
(How the Hell do you do subscript and superscript in the new forum's mark-any-way-but-up?)
Thank you for your response.
cus i use arduino uno i have precision 6 or 7
The result is as correct as it is going to be.
Log10(223) = 6.923
Log<sub>10</sub>(2<sup>23</sup>) = 6.923
You need IEEE 'binary64' (aka 'double') to get 53 bits of precision (15.95 decimal digits). Unfortunately, the avr-gcc runtime library doesn't support 'double' and uses 'float'.
Maybe this 'double precision on Arduino' library will help:
https://github.com/mmoller2k/Float64
If you use an Arduino with an ARM processor, type double is supported. The Teensy 3.x and 4.x series is much faster and has more memory than the Uno, too.
thnx .. i use just the uno ... i can't use ARM in my projct
I tried the Float64 library for you. It has a bug in "toString()" and was hanging in Serial.print(x[i]); on the second iteration. Commenting out a 'printf()' call in the library's 'toString()' function eliminated the hang.
#include <Float64.h>
f64 x[10] ;
int r =  4;
  delay(200);
  // x[1] = f64(0x3fe944aa, 0xa234953c); // 0.789632145698 converted with https://gregstoll.com/~gregstoll/floattohex/
  x[1] = atof64("0.789632145698");
  x[1].setDecs(16);  // Set number of decimal places to display
  Serial.println(x[1]);
  for (int i = 2; i < 10 ; i++)
//    Serial.println("Calculating...");
//    Serial.flush();
    x[i] = f64(r) * (x[i - 1] * (f64(1) - x[i - 1]));
//    Serial.println("Calculated.");
//    Serial.flush();
    x[i].setDecs(16);
//    Serial.println("Printed.");
//    Serial.flush();
void loop() {}
Results:
0.78963214569799
0.66445288071349
0.89182100010013
0.38590521552211
0.94792952061977
0.19743657822935
0.63382150322574
0.92836722109760
0.26600609555646
thank you sir . It works well
To help anyone searching for help on the same subject can I suggest that you revise the title of this topic. It is not help with 16 bits you need but rather 16 decimal places
