how to use plx-daq to compute readings from mpu-9150
hello,i want to get the raw data from mpu-9150 to excel using plx-daq.The plx-daq is connecting but now showing the data.Here is my code
// I2C device class (I2Cdev) demonstration Arduino sketch for MPU9150 class
// 10/7/2011 by Jeff Rowberg jeff@rowberg.net
// Updates should (hopefully) always be available at GitHub - jrowberg/i2cdevlib: I2C device library collection for AVR/Arduino or other C++-based MCUs
// Changelog:
// 2011-10-07 - initial release
I2Cdev device library code is placed under the MIT license
Copyright (c) 2011 Jeff Rowberg
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the “Software”), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
THE SOFTWARE.
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#include “Wire.h”
// I2Cdev and MPU9150 must be installed as libraries, or else the .cpp/.h files
// for both classes must be in the include path of your project
#include “I2Cdev.h”
#include “MPU9150.h”
// class default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for InvenSense evaluation board)
// AD0 high = 0x69
MPU9150 gyro1(0x68);
MPU9150 gyro2(0x69);
//int16_t ax, ay, az;
int16_t gx = 0, gy, gz ;
int16_t gx2 = 0, gy2, gz2 ;
#define LED_PIN 13
bool blinkState = false;
// join I2C bus (I2Cdev library doesn’t do this automatically)
Wire.begin();
// initialize serial communication
// (9600 chosen because it works as well at 8MHz as it does at 16MHz, but
// it’s really up to you depending on your project)
Serial.begin(19200);
// initialize device
Serial.println(“Initializing I2C devices…”);
gyro2.initialize();
gyro1.initialize();
// verify connection
Serial.println(“Testing device connections…”);
Serial.println(gyro1.testConnection() ? “MPU91501 connection successful” : “MPU91501 connection failed”);
Serial.println(gyro2.testConnection() ? “MPU91502 connection successful” : “MPU91502 connection failed”);
// configure Arduino LED for
pinMode(LED_PIN, OUTPUT);
// read raw accel/gyro measurements from device
gyro2.getRotation(&gx, &gy, &gz);
gyro2.getRotation(&gx2, &gy2, &gz2);
// these methods (and a few others) are also available
//gyro.getAcceleration(&ax, &ay, &az);
//gyro.getRotation(&gx, &gy, &gz);
// display tab-separated accel/gyro x/y/z values
// Serial.print(“g:\t”);
Serial.print(gx ); Serial.print(",");
Serial.print(gx2); //Serial.print("\n");
// Serial.println(gz);
delay (1000);
// blink LED to indicate activity
blinkState = !blinkState;
digitalWrite(LED_PIN, blinkState);
Please edit your post and add code tags ("</>" button).
What you have posted is not complete.
You may have a problem because the version of Excel is too recent. I understand people have claimed PLX will work on recent versions, but the general view is that office 2003 is the newest you can use - I think.
You can test your code is kosher by sending it to the monitor in the usual manner
I believe the only code you have that matters is
Which looks a bit naked in view of the absence of Excel commands, and I guess you are doing nothing to feed the y-axis.
A more typical feed to Excel might be
 Serial.print("DATA,TIME,");  // Excel commands
  Serial.print(InTemp);
  Serial.print(" ,  ");
  Serial.print(OutTemp);
  Serial.print(diff);
  Serial.println(DrainTemp);
Time to y-axis
Note that each record's ending is noted by using println(), not print().
